Results 1 to 3 of 3
  1. #1
    Join Date
    Feb 2006
    Posts
    75
    CT, Litchfield County
    BX24 TLB & old JD 400, JD H140
    Default 3 pt hitch and backhoe
    Where do the 3 pt hitch arms go when the backhoe is installed? (ie on a BX23 or BX24)
    Jim
  2. #2
    Join Date
    Aug 2005
    Posts
    739
    Saltspring Island, BC, Canada
    Kubota L3130HST
    Default Re: 3 pt hitch and backhoe
    I don't know about your machine but on my L3130 with a BH90 backhoe, The 3ph arms are removed. The lower arms are fixed with pins which are bolted on and the top arm is fixed by a clevis pin. Takes about fifteen minutes to take off the arms and mount the backhoe.If your backhoe has a subframe, I would guess you'd be the same.
  3. #3
    Member
    Join Date
    Mar 2004
    Posts
    34
    Hudson,New Hampshire
    BX23......RTV1100
    Remove the 3PH and store the parts in the garage then attach the BH
    Marc
    BX23
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
