ScottGilfordNH
New to group and forgot to attach schematic on original post. I have a BX2200 I bought used (155 hours-now at 385hours). Water has shut me down each time it rained and the tractor got wet. I drained the filters and part of the tank each time it rained. The stock filters can not handle water separation. I found the culprit to be the fuel tank sender unit on the left wheel well(when you are sitting on the tractor). I would not be surprised if you are leaking fuel from this location when you top off the tank. There are a lot of pieces that come off the tractor to get at the tank, but it is not really that hard. The fuel sender sits in a recess on the top of the tank. Water collects in the recess that the fuel sendor unit sits and leaks past the rubber bushing that is suppose to seal the sendor unit. Gravity holds it in place and over time, the seal fails. This is a poor mounting design! Kubota sells a replacement kit and not just the seal (rubber bushing). I also purchased a new tank because I had a main tank leak. I noticed the tank pn has changed. The parts alone cost over $220 for this repair. I don't know if the stock tank will accept the fuel sendor replacement kit. I am not going to all this work and still risking a leaking tank. For the future, I installed a DAHL 75 filter water seperator and mounted ont he bucket loader frame on the left side. This is a superior filter to what Kubota offers. I have photos/schematics that better explain this.
I did speak to my parts guy (Ronnie at tractorsmart.com) and the earlier model BX2200 I have was upgraded (TSB). The Bush Sensor Fuel PN K2561-61390 has been superceded by Kit Fuel Sensor pn K2561-96140. The new mounting design allows a compressive load to be put on the gasket and increases the friction fit as it expands against the tank opening. The kit has bolts that drive in real hard that get tightened up to in crease the seal of the rubber bushing. The kit will fit the original tank I am told. The oringinal tank was upgraded and reinforced from PN K2561-54710 to K2561-54700.
Scott
Scott
