Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Gold Member
    Join Date
    Jan 2011
    Posts
    463
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota B3300SU 33-hp / 1,900 pounds
    Default Re: Tilling using box blade rippers
    Quote Originally Posted by RonR View Post
    I have had some success in pulling dirt from one place to another. I am real nervous that backing with it might bend the 3PH arms.
    There are numerous posts on T-B-N from others cautioning against over-stressing lower link arms in reverse. After all, lower links are designed to pull, not push. I have replaced Kubota CHECK CHAINS/TURNBUCKLES with rigid stabilizers from Stabilworks, which reinforce the lower links in reverse as well simplifying mounting of implements to the 3-Pt. hitch.
    I am still cautious, but I now regularly push LOOSE dirt with the box blade. See photo. LOOSE DIRT!
    LINK:
    Kubota tractor stabilizers Kubota www.stabilworks.com - YouTube
    Kubota B3300SU / 33-hp / 1,900 pounds / 4-WD
    Attached Thumbnails Attached Thumbnails Tilling using box blade rippers-img_0463.jpg   Tilling using box blade rippers-img_0478.jpg
  2. #12
    Gold Member
    Join Date
    Jan 2011
    Posts
    463
    If you need more penetration do not hesitate to remove one or two rippers, concentrating implement weight on reduced number of rippers. On my 'Bush Hog' Rollover Box Blade rippers drop off after removing one 3/4" nut/bolt/washer per ripper.
    In photo I was ripping very tough Bahia pasture grass prior to raking Bahia, then seeding and rolling wildflowers.
    Three rippers in use, two removed. Box blade weight = 630 pounds.
    Attached Thumbnails Attached Thumbnails Tilling using box blade rippers-img_0541.jpg
  3. #13
    Platinum Member workinallthetime's Avatar
    Join Date
    Nov 2006
    Posts
    944
    Tulsa, ok
    b3030 TLB,zd326, polaris rzr s
    -tried the box blade method last year, way way to much seat time. found a used disc for 350, paid 320, added some weight to it and the garden looks great.
    -my lower link arms are are fine but whatever you call those adjustment arms are bent to heck, from pushing the box blade. Mine adjust with pin holes not tunbuckels
    -crazy old thread i was thread, i was excited "home brew" was back, that cat seemed to be the "grand po ba" on little bota's and fabing up implements for them. To bad he was banned for speaking out
    "EVERDAY I'M SHUFFLEING" ZD326, B3030 TLB, Toothbar, Thumb, 07 gmc vmax
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
