Results 1 to 9 of 9
  1. #1
    Join Date
    Nov 2001
    Posts
    48
    Calhoun County, Alabama
    Kubota 7500 w/ FEL
    Default Step for Kubota
    I have a B7500 and am fairly short (5'3") and my knees arn't getting any younger. Some mornings when my arthritus is acting up I find it hard to climb into the seat of my tractor. I was hoping one of you fine folks might know if there is a 'step' I can have added to the tractor to give me a leg up?
  2. #2
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,559
    Texas
    Default Re: Step for Kubota
    Thumper, I don't know of anything ready made to just bolt on, but I sure know of several metal fabricators/welders who could make one if I couldn't make it myself. I'll bet there are several in your area, too. If I were you, I'd take a picture of the left side of the tractor and stop by a couple of welding shops and ask. Or simply ask your tractor dealer. I would expect them to know of some shops that could do the job, it they don't do things like that themselves.
  3. #3
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,716
    Nova Scotia, Canada
    Would one of the small steps for trucks work?
    Egon
  4. #4
    Join Date
    Feb 2001
    Posts
    415
    Michigan
    Kubota B7100HST & Kubota L4610HST w/FEL
    thumperjb
    attached pic of step off of L series. probably available thru your dealer. it's not heavy duty, so keep it out of the rough stuff like stumps and rocks. 12"wide x 8" high. maybe could be mounted w/ couple pcs. angle iron.
    regards
    Mutt
    Attached Images Attached Images
  5. #5
    Join Date
    Oct 2001
    Posts
    1,163
    Upstate NY, USA
    Kubota L3710 HST and a Kubota ZD21 60Pro
    thumperjb, I've seen guys suspend a peice of flat iron from 2 short lengths of cable, (picture a rope ladder). You can have the step as low as you want, or add add 2 rungs. No danger destroying the thing on rocks/stumps, it'll just bounce off. If you make it too low, be sure the cable attachments are the weak point, you don't want your platform to be the point of failure if it catches on something... JJT
  6. #6
    Join Date
    Apr 2001
    Posts
    262
    NorthEast,CT
    B2710 HST,TLB R4's
    thumperjb
    You did'nt say if you had FEL. On my B2710 I fabricated an
    L shaped bracket strong enough to support my weight and used
    an existing hole in the loader frame to attach. Had to make
    threads ...7/16" I believe. It has held up very well. Make
    sure to make the surface non skid.
    RayBee
  7. #7
    Join Date
    Nov 2001
    Posts
    48
    Kubota 7500 w/ FEL
    Thanks, I will look under the FEL braces this weekend and see if my B7500 has a hole there. This sounds like a job I could do w/o hauling my baby to a welding shop, I don't have a trailer and I was looking to avoid that as long as possible. Now if I can just think of something other than 'Gorilla Glue' to attach hooks to the top of the bucket. [img]/w3tcompact/icons/smile.gif[/img]
  8. #8
    Join Date
    Mar 2000
    Posts
    40,559
    Texas
    Thumper, how about drilling a couple of holes and attach a hook with a U-bolt. I did mine like the picture shows so the hooks lay back out of the way of putting the fork lift forks on.
    Attached Thumbnails Attached Thumbnails Step for Kubota-15-90369-buckethook2-jpg
  9. #9
    Join Date
    Nov 2001
    Posts
    48
    Kubota 7500 w/ FEL
    I hadn't even thought of that, Thanks [img]/w3tcompact/icons/smile.gif[/img]
    I didn't think of bolting them on, thought welding was the only way. That should work for me thought as I doubt if I will be putting a great deal of weight on my hooks, I am still being real gentle with my 'baby' sorta like a new car you hate to put the first scratch on it. I don't mind all the scratches on the bucket but the first scratch on the tractor itself will no doubt hurt me more that it does the tractor.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
