Gator Blades for BX decks
   / Gator Blades for BX decks #2
I put them on a few weeks ago, $40 delivered from Jack's Small engine. Yes, you need bushings, my brother machined mine. PN# Gator 90987. Dramatic improvement in deck performance IMO. The stock blades have poor lift. I've mowed with a big Scag and then a Grasshopper, both are far superior dedicated mowers. The Gator's won't bring the BX up to that level, but it's much better and good for a general purpose machine.
- Patrick
   / Gator Blades for BX decks #3
Yes, in fact I just put mine on yesterday, after reading several posts on this forum. I can second upgw's findings, it's a big improvement, but still not as good as my old 48" walkbehind.
I made my bushings by buying a Cat 1 to Cat 2 adapter bushing. I believe they are 7/8 x 1 1/8. I used a hacksaw to cut off 3 separate approx. 1/4" rings to use as the bushings. I found that they were too tight to press into the blade, so I simply cut thru one edge of the ring so that it could easily compress into the blade. Pretty simple.
Mike
   / Gator Blades for BX decks #4
My bushings were also made from cat 1 to cat 2 bushings, used vise and they pressed in perfectly.
   / Gator Blades for BX decks #5
Hate to bring up old posts but wanted to comment on this one.
Useing the above mentioned cat1 to cat 2 bushings I also adapted a brand new set of gatorblades to the 60" MMM on my BX23 and their cut & performance far exceeded what I was getting from the stock blades.
I may retry the ole home made mulch plug again :D
Pic 1 shows the cut of the std blades.
Pic 2 shows the cut of the gatorblades.
   / Gator Blades for BX decks #6
Volfandt
WOW that is good performance! It looks like it sucked the leaves off that tree in the center of your yard:D
John
   / Gator Blades for BX decks #7
Not bad eh? :D :D
Actually most all of those leaves had fell on their own accord and the BX w/the afore mentioned gatorblades made mincemeat outta them :D :D
Volfandt
   / Gator Blades for BX decks #9
Hey Tom, I took the liberty to post your link to the blades over there. Your price beats mine by nearly $8 !!!
Once you get 'em mounted your machine too will be suck'n the leaves off those dasturdly trees :D :D :D
Volfandt
   / Gator Blades for BX decks #10
I just installed a set of gator mulching blades on my BX2200. 54" deck and they work great :D. I am very pleased with their performance. Even though these are the magnum mulcher's and are not supposed to lift the grass like the high lift blades, they do lift the grass rather well. I could definitely tell a difference. Because it was 7 days since I had last mowed, I left the bagger on to collect the grass. I was afraid that the grass would be too high to mulch. I usually empty the bagger 4 times with the regular blades on. Today I only emptied twice with the mulchers on. They really make a fine cut. Attached are several photos.
Bill
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
New 2025 NextGen 7x12 Utility Trailer (A51573)
New 2025 NextGen...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2017 JOHN DEERE 8270R LOT IDENTIFIER 176 (A53084)
2017 JOHN DEERE...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A51248)
UNUSED RAYSKY...
