azhfl56
Member
I was looking for some advice. I am new here, thought I have been lurking for some time. At any rate, I just purchased a brand new Kubota 4330 Cab model. When the dealer installed the controller for the front end loader, it would seem they did not use the supplied template for installation. In order to install the fel control they must drill through the fender. Now the fel control is in the wrong place. It hits my knee and does not allow the rear lift control to go all the way down, because the lever for the rear lift control hits the fel control. There is no hope of adding draft control because there would be hardly any clearance for the second lever. The installer also managed to seperate the seam bonding the fender to the cab body. The inside of the fender is now bent and seperating, the spot welds have been popped.
Up until this point the dealer has been great. What do I do? In order to fix it the right way, in my opinion they would have to order a new fender. However, what is saying that the same careless bloke or his co-hort don't do worse? I am really confounded on what to do. I know that if you just bought a brand new car and the dealer installed something that had to be drilled and drilled the holes in the wrong location, the item they drilled would be replaced.
I don't want a bunch of extra holes, but I don't want to be mean either. I know mistakes happen. I am just a little irked because Kubota supplies a template and the installer decided not to use it.
Any advice appreciated
Regards,
Bryan
Regards,
Bryan
