Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default On last problem noticed
    Sorry to keep posting and bugging you all but I also noticed one other strange thing on my recently purchased B7100. The front end. (4wd model) moves back and forth approx... 3/8 to 1/2 inch on the bolt(pin) that it pivots on in the center of the differential. Example: When the tractor is sitting still in the garage and I move the steering wheel left or right, The front end (wheels), acually move either toward the rear tires or away from them, depending on which way I turn the steering wheel. The same thing will happen if lets say I run over a rock or something similar. Is it normal for these things to move forward and backward a bit on the pivot bolt(pin). Thanks again to all. Brian
  2. #2
    Epic Contributor Bird's Avatar
    Join Date
    Mar 2000
    Posts
    40,865
    Texas
    Default Re: On last problem noticed
    Sounds like you have a little wear problem. Can you jack up the front end and tell whether the pin or bolt is worn or whether the holes it's through are worn, or whether it's just loose and needs tightening? Whichever it is, I'd say it's not normal.
    Bird
  3. #3
    Join Date
    Mar 2000
    Posts
    425
    New York state
    Kubota B1700 HST
    Brian - not sure the 7100 is the same as my 1700, but I bet it is. Mine has ZERO front to back looseness, and I bet yours should be the same. May be as simple as tightening that bolt on the front pivot, but I am guessing. Hopefully nothing like a bushing or the pivot pin has worn to the point where you need to replace it. I would either get a service manual, talk to somebody who knows for sure, or take it to the dealer ASAP.
  4. #4
    Join Date
    Mar 2000
    Posts
    425
    New York state
    Kubota B1700 HST
    Uh, Bird, looks like great minds think alike.
  5. #5
    New Member
    Join Date
    Sep 2005
    Posts
    0
    BUMMER!! Now I own a Oil leaking worn out kubota. Anyone know of any good used Dynamarks or Gravelys for sale or trade? Thanks again guys..
  6. #6
    Join Date
    Mar 2000
    Posts
    40,865
    Texas
    I think you'll be better off just getting the kubota fixed up, Brian.
    Bird
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
