Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    Veteran Member Dusty's Avatar
    Join Date
    May 2000
    Posts
    1,050
    bx1800
    Default Re: BLock Heater install project - BX2350
    Your tractor will start in cold weather, but it won't like it. It will bang and thrash around until the engine gets warm. As shown in the pictures, it is next to impossible to do anything wrong removing the freeze plug. If you are concerned about it going into the block, then have the dealer do the install. I never recommend that someone do any mechanical operation that they don't feel comfortable doing. Either way, you should have a block heater installed, even if you have to pay to do it. The reduced wear and tear on your tractor will more than offset the cost of the heater and installation. Dusty
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    Posts
    Register now to remove this ad.
  3. #22
    Gold Member Renob's Avatar
    Join Date
    Feb 2006
    Posts
    252
    Finger Lakes, NY
    Kubota B2620 TLB
    Slapped the block heater in the BX24 today. Went in without a hitch!
    Chaliebrn - Killian's sounds good, but went with a Labatt's Blue to complete the project!
    Fishpick - As Dusty said, It is almost impossible to mess up the freeze-plug removal. The way the block is designed there just isn't enough room for this plug to fall in the block.
  4. #23
    Platinum Member fishpick's Avatar
    Join Date
    May 2006
    Posts
    698
    The part of NY with high taxes
    NH TC45DA & Kubota BX24
    I'm still thinkin' about it... I'm not really that worried about the job... just not sure I need it for the time/reward factor to kick in.
    Did you paint yours too? Or just drain, KO the plug, jam the new one on in and drink a beer?
    For the latest in what's going on around the farm and homestead check out our podcast Chicken Thistle Farm Coopcast, our site Chicken Thistle Farm or join the discussion on Facebook and Twitter!
  5. #24
    Join Date
    Jan 2001
    Posts
    929
    NW Ohio
    Kubota BX-2350
    Not sure if Renob painted it or not, but Kubota recommends it to prevent corrosion. I agree...it just looks like it needs painting....
    Renob: Good second choice on the Labatts! *cheers*
  6. #25
    Join Date
    May 2006
    Posts
    698
    OK - I hate to do this because this thread seems to spring up everywhere... BUT... what color paint did you use to match the block and where did you get it... (see, sounds like I'm gonna do it, huh?)
  7. #26
    Join Date
    Feb 2006
    Posts
    252
    Finger Lakes, NY
    Kubota B2620 TLB
    I used Plasti-Kote Engine Enamel Universal Gray that I purchased at TSC.
    It seems to be a good match. At least in an area that will never be seen.
  8. #27
    Join Date
    Dec 2000
    Posts
    193
    Saskatchewan, Canada
    Kubota BX1830
    have any of you used the magnetic block heaters that go on the bottom of the oil pan. Or are they any good.
  9. #28
    Platinum Member bigdad's Avatar
    Join Date
    Feb 2006
    Posts
    598
    West Central Illinois
    Kubota B7510
    Yessir..... I have used them. Old air cooled trencher engines to be exact. Also used them on fuel tanks for diesel trucks. I tried one on my 7510 and couldn't get enough surface for the mag to work. Ended up with a prefered block heater, which is noted here on this forum somewhere.
    Be careful...they get hot!
  10. #29
    Gold Member
    Join Date
    May 2006
    Posts
    359
    Spring Mount, PA
    Kubota BX24
    Another option, if they still make them, is the dipstick tube oil heater. Keeps the oil warm and the engine easier to turn over. Nice and clean for those mechanically shy, nothing to take apart on the tractor.
  11. #30
    Join Date
    Sep 2001
    Posts
    1,771
    Kansas
    Kubota L3000DT
    With the variety of thin oils (especially synthetics) available, heating the oil is probably not nearly as beneficial as it once was.
    The block heater adds warmth where it is needed most--the combustion chamber.
    Meetings: If more than two people are there, at least one's time is being wasted.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
