Results 1 to 7 of 7
  1. #1
    Member
    Join Date
    Jan 2007
    Posts
    41
    West Tennessee
    Kubota L1500
    Default Kubota L1500 "back in baby's arms"
    I brought kubota home today. Mechanic installed new glow plugs and machine is starting right up. I even puttered around on her on my land. Thanks to everyone for their opinions and advice. More thanks for not berating me for making a rookie mistake. I was prepared for the worst but pleased with the result. Now I am back to continuing my maintenance that I think this machine needs. I snapped some pictures of what I think is the transfer case. I want to change this fluid. Is the hex head cap screw on the side the fill line Pictures 10 & 12)?
    Thanks again everyone!!
    Watgad
    Attached Images Attached Images
  2. #2
    Join Date
    Sep 2006
    Posts
    99
    Adelaide, South Australia
    Kubota B7100D
    Default Re: Kubota L1500 "back in baby's arms"
    Glad it's back working!
    Apropos the oil - the filler is the obvious, but the level is usually set via a dipstick. I can see one near the gear shift. As far as I know, there is only one oil source for the gearbox, hydraulics and "transfer case". My little B7100 takes 10 odd litres of oil - you need oil that does hydraulics too. There is a bazillion postings about what to use elsewhere in the forum - I just use kubota UDT. Draining the oil on my B7100 involves undoing the bottom bolt on the rear axle drive casings (both sides). I'd assume the L series is similar. The operators manual is handy for showing these!
    There should also be a giant (mine is 26mm) bolt holding a banjo fitting that feeds hydraulic oil to the FEL or whatever you might have. You need to remove this bolt and clean the filter sleeve on it when you have dropped the gearbox oil. The hydraulic pump on the smaller Kubotas is on the rear of the injector pump, tracing the pipe work is pretty straight forward. Removing the filter bolt on mine involves removing the right hand rear wheel - there isn't enough clearance to withdraw the bolt with the wheel in place
    Happy maintaining!
    /Kevin
  3. #3
    Member
    Join Date
    Jan 2007
    Posts
    41
    West Tennessee
    Kubota L1500
    Thanks for the info Kevin.
    Watgad
  4. #4
    Super Member N80's Avatar
    Join Date
    Aug 2005
    Posts
    6,125
    SC
    Kubota L4400 4wd w/LA 703 FEL
    Do you have a manual for this tractor? You might be able to find one at Tractor Smart:
    TractorSmart home page
    George
    South Carolina
    "What is truth?" Pontius Pilate
  5. #5
    Member
    Join Date
    Jan 2007
    Posts
    41
    West Tennessee
    Kubota L1500
    Thanks George. I e-mailed my info to tractor smart.
    Watgad
  6. #6
    Member
    Join Date
    Jan 2007
    Posts
    41
    West Tennessee
    Kubota L1500
    Tractor smart sent me a parts manual. Where can I obtain an operating/service manual?
    Watgad
  7. #7
    Join Date
    Jul 2006
    Posts
    111
    midwest
    B3030
    Try Messick's, they are cheaper than my dealer for some reason and they're supposed to be real kubota manuals from what I've read in the forums.
    "Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." Ronald Reagan
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
