BigJimSlade
- Joined
- Feb 4, 2007
- Messages
- 5
Hello there,
I had a peculiar thing happen to my tractor yesterday and I am looking for advice on how best to deal with this problem I have.
I have a Kubota L245DT probably manufactured for the Australian market in the mid 80's. The tractor was working fine the day before last and the next morning I get in it start it up put it into reverse and go to drive out of the shed when suddenly a fountain of oil shot out of the lower right hand side of the block. I switched it off right away and took a look.
I found a small cylinder of metal in the oil on the floor. It is about 5mm long and 5mm wide with a small step on one end of it. This bit of metal had popped out of a hole in the crank case just below the oil filter.
I have looked through the workshop manual and found nothing but in the maintenance manual in the exploded engineering drawings it just says that thi s is a plug but worse than that a plug with a thread and a bolt head. So the manual isn't exactly like my tractor (nothing new there!) so I searched on the net and found references to core plugs.
From what I can gather this bit of metal that popped out is a core plug that has been inserted into the block after the block is cast. The core hole is from the casting process.
Now the funny thing is on ringing around noone has heard of this problem and they all say core plugs shouldn't come out.
So has my core plug just worked its way out over the years or is it a sign of something more serious like too much oil pressure in the crankcase.
Why didn't the oil pressure relief valve handle this? What is this relief valve and where is it. I cant find a reference to it in my manual.
Any suggestions or help will be much appreciated
Cheers
BJS
Cheers
BJS
