SCDolphin
Gold Member
Wow I drove a L5740 today with the new Auto Throttle Advance. I thought it might be a gimmick but all I can say is WOW WOW WOW!!!! I am now more than ever convinced that this is the best CUT out there.
LaVita said:Can someone articulate what it is? How is it different from the Lxx30 HST?
Glowplug said:Sounds like a bunch of fancy-schmancy gobbledy-gook to me! Just give me a stick and a clutch pedal any day!
Me too. In fact, I've never met an automiatic transmission I liked in any vehicle. I guess I'm just a control freak.
However, I guess if it was my job to spend all day, every day on a tractor, I'd appreciate all the amenities I could find.
That's pretty much the case. Just set the throttle lever as low as it goes (or anywhere for that matter) and then step on the pedal. The further you step the more you go, just like a car. The transmission uses the anti stall features to keep everything honest.milkman said:Hmmmm. Could this be the step to eliminating the need to learn to use a tractor with a HST? A lot of inexperienced users, when the load gets heavy, tend to push down on the pedal, and then come to the conclusion that the hydrostat doesn't pull as good as their gear tractor.
