l4350mdt
   / l4350mdt #1
Bigk56
commerce, ga
kubota L4350
Could anyone tell me what year model this tractor is by the serial number. Contacted a dealer with no luck. L435-60835 is the number.
Thanks, Ken
   / l4350mdt #2
Hi Ken,
Since your S/N is 447 away from mine (also an L3), 1994-1995 would be my guess - but a dealer can contact Kubota and get the actual date the tractor was first sold at retail. The "year" of the tractor is determined by the sale date. Perhaps one of our dealer members will post the original sale date for you.
Sorry your other thread on the L4350 got off-course. You had asked about tire sizes - there is a very good article on this at TractorSmart - look under the Info Tab. Take care, DickB
   / l4350mdt
Any help on the serial number? By the way I've torn down front end and have right front kingpin assembly sitting on the workbench. I'm waiting on new seal to arrive. Hopefully I'll have it in a few days and I can get it up and running.
Ken
   / l4350mdt #4
Sent you a PM about number. Any chance you can post some pics of the kingpin job? Dick B
   / l4350mdt
   / l4350mdt
I removed bevel gear case and put it up on the bench. The upper race for the thrust bearing is a press fit. I heated it a little so it would release from the shaft and slide off. I removed old seal and cleaned up shaft with scotch brite pad. I drove on new seal with an old enfamil can I keep bolts in the shop. It was just the right size. This pic is the bevel gear case upside down on table with new seal, and upper thrust bearing race reinstalled.
http://http://www.tractorbynet.com/forums/attachment.php?attachmentid=76749&stc=1&d=1179050730
Approximately 250 Traffic Cones (A51573)
Approximately 250...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
