Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
  1. #11
    Veteran Member Redbug's Avatar
    Join Date
    Aug 2004
    Posts
    2,033
    Columbia, SC
    Kubota L3830HST
    Default Re: Land Clearing ~ 30 acres
    Thank you Cbturf! You answered the things I did not know and was wondering about. I am planning ahead much like Tim, and looking at the different options for developing and clearing an area. I think if you have patience and three years or so, keep the stumps killed off so they will rot, mulching is a good way to go since there is less disturbance to the soil, and probably much cheaper.
    Dave
    "If your sport does not put grease, blood, or dirt under your fingernails, then it's just a game!"
  2. #12
    New Member
    Join Date
    Oct 2008
    Posts
    23
    The very first thing to do would be contact timber consulant to sell your timber. He will "cruise it" (estimiate the value), and then you can proceed from there. He will usually charge 10%, but what he will do its put it out for bids. Most of my past bids (from my previous 2 sales) have varied as much as 60% difference from one buyer to the next. Hard to say how much value you have, but it will be well worth your time. THis will take out the large stuff and hopefully give you the capitol to clear the rest.
    Use a track hoe on the stumps, and a loader to push up the rest into burn piles.
  3. #13
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    First organized permanent settlement in the northwest territory
    2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
    Quote Originally Posted by Redbug View Post
    Good questions Tim. Interesting thread. I do not want to seem like I'm hijacking your thread, though. I have wondered about the mulching vs a dozer for land clearing and making fields/open areas. I plan to buy acreage in the near future and will follow a route much like Tim, eventually building a house following retirement.
    A couple questions to the group about mulching if you don't mind... I know that if a dozer or track hoe comes in and cleans up, you can burn the debris to get rid of it. Stumps and all. With the mulcher, it lays and rots. And you can bush hog it immediately. If you want to make pasture, after the land was mulched...won't the tree stumps sprout back up? How deep will a mulcher grind? Would a person be able to disk or till the land after it had been mulched, and raked out? Or
    do the stumps have to be dug anyway?
    Wouldn't these be hard on a tractor and plow if you didn't?
    Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500.
    Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
    60'' MMM/Clamp on Forks/48'' MMM
    South of Canton Ohio L .B
  4. #14
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    Quote Originally Posted by cbturf View Post
    The cheapest option is to just grind the tree off to ground level and keep the regrowth cut and it will eventually die and decompose this is the cheapest option but also takes a few years.
    I grubbed/cleared .6 acre here a couble of years ago.
    Do you think the roots and stumps have
    decomposed yet ?
  5. #15
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    Depends on the wood, the weather and the soil. Moist soil, warm temps and soft woods will go quick. Oak roots will last a long time
    You can speed the process up by adding some lime and high N fertilizer. That will feed the bacteria that munch it down.
    j
  6. #16
    Super Star Member
    Join Date
    Oct 2004
    Posts
    16,854
    Quote Originally Posted by john_bud View Post
    j
    Thanks.
    Hard to tell what the decompsure stage is now.
    It's all burried.
  7. #17
    Join Date
    Apr 2005
    Posts
    703
    Sumter, SC
    Massey Ferguson 5609, Kubota GS1800, eXmark LazerZ XP
    Planning ahead... I started this thread back in 2008. Five years later the woods are being clear cut in preparation for putting in additional pastures. What cannot be converted to pasture will be replanted in pine. Talked to a few people about mulching and the rough consensus I've heard is the stumps are too big. Some of the stumps are 24" to 36" in diameter (trees are cut off as close to the ground as feasible). Some folks are talking excavator. Others say a big dozer is faster. One guy has a Morbark 4600XL for shredding stumps others are saying windrows. I've heard prices ranging from $1,200 an acre (dozer out of TN) to $3,000 per acre (excavator and burn piles).
    Now I need to find a competent contractor with the right equipment at the right price.
  8. #18
    Platinum Member tonyoz's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Queensland & Far South Coast NSW Australia
    Rayco
    Someone in your neck of the woods has gotta have a big HP stumpgrinder. It's far better to use these than digging stumps out then prosessing them either by carting to heaps and burning or mulching. To give you some idea our stumpgrinder on a Rayco C140 can grind over 100 stumps an hour that range in size from 30" down and were 12" high with nothing more to do than run a chain harrow over the job.
    CTC Mulching
    I'm going to die without any enemies' in the world cause I will outlive the barstards
  9. #19
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,838
    Nova Scotia, Canada
    Look for a fellow with a larger dozer with a ublade and root rake. Then follow up with a breaking disk or plough. That will put you in shape to work the land and get pasture started.
    It ain't cheap.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  10. #20
    Join Date
    Sep 2009
    Posts
    559
    Rayco
    Quote Originally Posted by Egon View Post
    It ain't cheap.
    Then whatcha gunna do with do with the stumps?????
    CTC Mulching
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
