Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
  1. #21
    Silver Member McCaskey's Avatar
    Join Date
    Jan 2007
    Posts
    169
    East Aurora, NY
    Default Re: Running Carbides An Chippers on the same Drum?
    Think twice about the Planer Carbides.
    I spent a lot of money swapping out standard carbides for planers and results are disapointing on my Loftness Carbide Cutter. I have less than 100 hours on the new teeth and half are fractured and broken. The Standard Carbides lasted 700 hours without a single broken tooth. King Kong Tools is the OEM supplier for Loftness. The response from Loftness was "planers are best when used in areas where geology is entirely rock and stone free- a Carolina sand beach for instance." I don't have any rocks, only average vegetation that would be expected for any mulcher. The drum is now out of balance with broken teeth. Without material in the drum, the vibration is noticeable.
    Attached Thumbnails Attached Thumbnails Running Carbides An Chippers on the same Drum?-planar-tooth-damage-jpg
    2006 ASV RC100, Loftness Carbide Cutter, Erskine snowblower, Brushwolf 9000HF, 2003 New Holland TN65, 2014 Kubota RTV-X900, 1985 Jacobsen HR15, 1981 John Deere 400, 1979 Ford 7700, 1958 Wife
  2. #22
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    Try Quadco I've had nothing but good luck with Quadcos coppers, I did have king kong planners but had the same problem as mccasky broke very easy.
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  3. #23
    New Member
    Join Date
    Sep 2012
    Posts
    6
    Mineola, Texas
    Cat 287C, Vermeer SC 372, John Deere 6430
    On the quadco teeth how many hours did you get out of them?
  4. #24
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Quote Originally Posted by justinl
    I run a fae head quadco makes chippers and double tipped carbides, the chippers I get anywhere from 50-60hrs out of each side.
    Now if u have the old paddle style fecon rotor quadco has a holder that uses feller head teeth.
    HFM LLC
    251-331-4475
  5. #25
    New Member
    Join Date
    Sep 2012
    Posts
    6
    Mineola, Texas
    Yeah i got the older style head and I talked to Jim at quadco and he said he wouldn't run the feller teeth said they won't last very long he recommended the chipper tooth. Have you ever heard of the eagle claw brand of chipper teeth? They are about a grand cheaper a set than quadco and they claim to last about the same amount of time.
  6. #26
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Yeah I have heard of them but never give them a shot, I would try them out if there a grand cheaper.
    HFM LLC
    251-331-4475
  7. #27
    New Member
    Join Date
    Sep 2012
    Posts
    6
    Mineola, Texas
    Yeah I'm gonna try them out and I'll let you know.
    Thanks for your input
  8. #28
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    No problem
    HFM LLC
    251-331-4475
  9. #29
    New Member CustomConstruction's Avatar
    Join Date
    Jan 2012
    Posts
    16
    Hazlehurst MS
    Default
    I now see that quadco is making chippers for the bobcat head.. Anyone run them yet?
    Marc
    Custom construction LLC
  10. #30
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Quote Originally Posted by CustomConstruction
    Havent ran them on the bobcat head, but you'll be extremely impressed. You will think your in a different machine a much bigger machine.
    HFM LLC
    251-331-4475
Similar Threads
  1. Kohler running on one cylinder
    By jdgreg in forum Parts/Repairs
    Last Post: 08-04-2017, 04:09 PM
  2. Flail Mower Finally got the flail mower running....glad I got a beater!
    By ManAtArms in forum Attachments
    Last Post: 11-15-2009, 10:48 PM
  3. Pulling a Dexter drum brake axle
    By GreatWhitehunter in forum Trailers & Transportation
    Last Post: 10-08-2009, 12:25 PM
  4. Disk or drum brakes ?
    By Renze in forum Trailers & Transportation
    Last Post: 06-28-2007, 05:06 PM
  5. Disc vs Drum mowers
    By cowpie1 in forum Attachments
    Last Post: 01-21-2007, 11:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
