Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1
    Platinum Member tonyoz's Avatar
    Join Date
    Sep 2009
    Posts
    539
    Queensland & Far South Coast NSW Australia
    Rayco
    Default Cutter pump C140/FTX140
    Has anyone had a problem with the cutterpump on these machines and what was the diagnosis? Yesterday I got a bad rattle and lost flow and pressure in mine.
    CTC Mulching
    I'm going to die without any enemies' in the world cause I will outlive the barstards
  2. #2
    Gold Member WestshoreConstruction's Avatar
    Join Date
    May 2008
    Posts
    253
    The Great white North
    Default
    Quote Originally Posted by tonyoz
    Might want to check the pump drive. Any noise and subsequent loss of anything usually isn't good on a mulcher.
    Mulchers 100-600 Hp, Dozers, Excavators, Trucks, and a bunch of other stuff that cost me money every day.
  3. #3
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    This may or may not be your problem but last year I was on a job when my pump started loosen flow then spiking back up an kept doing this over an over also creating an rattle, then all the sudden had nothing going to the head. Got out expecting the worst, checked an found there was a safety switch going to the cutter pump that must have vibrated lose then feel out put it back in an, back to normal. Hope this helps
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  4. #4
    Join Date
    Sep 2009
    Posts
    539
    Rayco
    Default Re: Cutter pump C140/FTX140
    Well I've talked to some hydraulic people today and the consensus of opinion is to change the filters then pressure and flow test. Fair go, it would be just about easier to find rockinghorse poo than get these filters,got to be air freighted in. Cat, tried your suggestion and that plug is all good,thanks.
    CTC Mulching
  5. #5
    Join Date
    Sep 2009
    Posts
    539
    Rayco
    Well I found why the pump was rattling. Its the 4th 140 thats done this that I know about and all near the same hrs
    Attached Thumbnails Attached Thumbnails Cutter pump C140/FTX140-img_0159-small-jpg   Cutter pump C140/FTX140-img_0161-small-jpg   Cutter pump C140/FTX140-img_0162-small-jpg
    CTC Mulching
  6. #6
    Bronze Member APSmulching's Avatar
    Join Date
    Jun 2008
    Posts
    95
    Newton, NJ
    Fecon FTX140, Bombardier GT-500-HY, New Holland TC45DA
    Default
    Hard to tell, but looks like a roller bearing failure. How many hours are on your 140?
  7. #7
    Platinum Member DIRTROAD's Avatar
    Join Date
    May 2008
    Posts
    551
    SOUTH CAROLINA
    Carolina Clearing, LLC
    Looks expensive!!!! How many hours?
  8. #8
    Join Date
    Sep 2009
    Posts
    539
    Rayco
    Quote Originally Posted by DIRTROAD View Post
    Just on 3000hrs, expensive? **** yer been told to budget $20,000 for new pump and labor. Bloody heartbreaking I can tell you. It's just as well for some people I don't live near Ohio.
    CTC Mulching
  9. #9
    Join Date
    Sep 2009
    Posts
    539
    Rayco
    Quote Originally Posted by APSmulching View Post
    I would be pure speculation to the cause, the rotating group is so smashed up we cannot pin point to any one thing.
    It's the 4th one of these to do this in Australia that I know about ,all about the same hours
    CTC Mulching
  10. #10
    Elite Member
    Join Date
    Jan 2010
    Posts
    3,277
    Northern, IL
    Branson 2400H, JD X540
    Have you ever changed the filters on this unit? I presume their are charge pump filters and if they start to plug it can cause this type of damage. Suspect one of the slippers failed and scrapped the rest of the unit.
    You will also have to inspect and probably replace all of the hydraulic motors on this unit also. All that debris went somewhere.
    Roy
    Artificial Intelligence will never overcome natural stupidity.
    Branson 2400H MMM & FEL
    JD X540
Similar Threads
  1. Rotary Cutter JD 5105 tractor with JD MX 6 rotary cutter quits cutting
    By texasjohn in forum Attachments
    Last Post: 06-09-2011, 11:53 AM
  2. possible well pump problems?
    By merrickvilleguy in forum Rural Living
    Last Post: 05-28-2011, 08:00 PM
  3. the name of the pump ?
    By hodinhtran in forum Hydraulics
    Last Post: 11-19-2010, 10:56 PM
  4. PT-425 Engine Removal Procedure [Long]
    By SnowRidge in forum Power Trac
    Last Post: 04-12-2009, 09:20 PM
  5. IH 384 injector pump issues
    By CGTech in forum Case-IH
    Last Post: 09-14-2004, 09:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
