Page 2 of 8 FirstFirst 12345 ... LastLast
Results 11 to 20 of 77
  1. #11
    Join Date
    Nov 2006
    Posts
    741
    Georgia
    Default Re: New Cat 299D XHP
    Cat PM sent
    Robbie Hegwood
    404-379-5897
  2. #12
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    Well just got my bubble popped salesman just informed me they won't be able to get there hands on a 299d xhp til the end of may first of june. He thought there was one at the birmingham store but sold by the time it came off the lowboy.
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  3. #13
    Join Date
    Jul 2007
    Posts
    989
    S. Central TX Hill Country
    If Cat fixed those few things from the C series that annoyed me when I was mulching, then they will have a heck of a machine. I miss my 272c for a lot of things but I don't miss the air filter/dust in cab issues and the debris in the engine compartment. Aside from that the c series was a fine machine. Put in the bigger motor and up the flow and it's making me want to go back to Cat.
  4. #14
    Join Date
    Dec 2010
    Posts
    55
    Central, IL
    3-Cat 299D XHP,1-Cat 299C, Cat 315DL,Cat 315CL,2-Jarraff
    Cat, That's when I first heard mine would be available, was suprised when the call came in early.
  5. #15
    Join Date
    Apr 2011
    Posts
    64
    NC
    299D XHP w/HM 415B mulcher
    Quote Originally Posted by yellowdogsvc View Post
    Waiting on my CAT sales rep to give me a quote. I think they may have finally listened to there customers. We will see! Good looking restructuring the best I can tell from spec sheets and photos anyhow. Seat time will tell the truth.
  6. #16
    Join Date
    Apr 2011
    Posts
    64
    NC
    Quote Originally Posted by ramzee1 View Post
    For the last few months we've had the privilage to run one of the 299D XHP prototypes for Cat. We have been running a HM 312 mulcher mostly on this machine but we also did run a 7' bush hog type mower and did some dirt work.The extra horsepower and the additional hydraulics are noticeable. Cat is saying 106 HP and 40 gal flow. We did check flow and it was 40 gal as they say.
    After a short time I knew we wanted to upgrade to one of these machines when they hit production, so I put my name on the list early and as of last Friday our new 299D XHP is in our possession. The new mulcher for this unit will be a HM 415, it's ordered but not in yet.
    Here's a few things, Cat rearranged the some of the components in the engine compartment, the air conditioner condenser is mounted on the back door plenty of air flow now. When the proto was delivered it was early August last year,at that time temperature was 95deg+ with humidity about the same. I had the air on the coldest setting with the fan on high and had the bottom 12" of glass fogged up. I actually had to turn the temp setting up after awhile. The fuel filter, oil filter, hydraulic filter and battery are at the back where it's easy to get to. The hydraulic oil level is easy to check and fill, it's mounted in the same area as before but below the arms for access. The fuel tank is larger 31 gallon now (I think). When we were mulching we were using around 3.5 gal of fuel per hour. The engine never ran hot, we did blow out the radiator every day.
    I had the debris kit installed on our unit, you can see in the pics some of the guarding and the precleaner location, big improvement from before. The proto we started with did'nt have the precleaner but was installed later, we went from cleaning the air filter every hour in very dusty conditions to once a week.
    I'm sure there are alot of things I'm forgetting so questions are welcome. I would rather not talk about the price, I feel you should talk with your local dealer or pm me and I'll give you my dealers info. My replies may be slow, I do use one finger from each hand so I am faster than some.
    Thanks, Russ
    Hey,
    Just wandering, If it's not to much trouble to ask,could you upload a pic of the engine compartment? The CAT Territory Rep is supposed to be getting me a quote and hopefully a factory tour in Sanford N C(About an hour away from my home) but haven't heard back from him yet. Thanks.
  7. #17
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Timberwolf, there is a video on you tube of the new 299d at a trade show over seas gives a good look inside the engine bay.
    HFM LLC
    251-331-4475
  8. #18
    Join Date
    Dec 2010
    Posts
    55
    Central, IL
    Timberwolf, first three engine compartment, fourth hydraulic tank fill area. Another thing I forgot to mention is the decelerator. When the engine speed control knob is turned all the way up your foot pedal becomes a decelerator. I forget it's there sometimes. I've been using it when I cross ditches, hook up attachments, pulling into the shed, and there's no more cable for the foot pedal it's electronic now.
    Attached Thumbnails Attached Thumbnails New Cat 299D XHP-dscn1226-jpg   New Cat 299D XHP-dscn1227-jpg   New Cat 299D XHP-dscn1228-jpg   New Cat 299D XHP-dscn1229-jpg
  9. #19
    Join Date
    Dec 2010
    Posts
    55
    Central, IL
    Fourth one not hydraulic tank fill area let me try again
  10. #20
    Join Date
    Dec 2010
    Posts
    55
    Central, IL
    I won't quit until I get or something's broke.
    Attached Thumbnails Attached Thumbnails New Cat 299D XHP-dscn1230-jpg
Similar Threads
  1. Cat 299d
    By 05rammer in forum Land Clearing Equipment
    Last Post: 01-31-2013, 07:13 AM
  2. How to convert Cat 2 Brush Hog for Cat 1 Tractor
    By swmich42 in forum Attachments
    Last Post: 04-13-2011, 09:42 AM
  3. More Visitors to the Prairie
    By RobS in forum Photos
    Last Post: 10-07-2008, 06:33 PM
  4. Cat 1 or cat 2
    By curly in forum Kioti Owning/Operating
    Last Post: 09-19-2007, 09:21 AM
  5. How to trap a skunk
    By roxynoodle in forum Related Topics
    Last Post: 10-22-2006, 09:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
