Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 77
  1. #21
    Join Date
    Apr 2011
    Posts
    64
    NC
    299D XHP w/HM 415B mulcher
    Default Re: New Cat 299D XHP
    Quote Originally Posted by ramzee1 View Post
    I won't quit until I get or something's broke.
    Thanks Ramzee1 and CAT for the info and pic's,VERY helpful. Now if my sales rep will get in touch.
  2. #22
    Join Date
    Nov 2006
    Posts
    741
    Georgia
    Ramzee, nice machine. One thing you have to do and one suggested. First get a true forestry door. The one on the machine is not. If you push in hard enough it will flatten out and fail, probably with injury to the operator. Not sure if Cat has one but I know Supertrak does. Second cover the two opening in front where you unbolt the cab to raise, those are two funnels for debri to enter the belly. Magnet sign material will work fine. I see they put weather striping down the side where the cab meets the frame.
    Robbie Hegwood
    404-379-5897
  3. #23
    Join Date
    Apr 2011
    Posts
    64
    NC
    Timberwolf, first three engine compartment, fourth hydraulic tank fill area. Another thing I forgot to mention is the decelerator. When the engine speed control knob is turned all the way up your foot pedal becomes a decelerator. I forget it's there sometimes. I've been using it when I cross ditches, hook up attachments, pulling into the shed, and there's no more cable for the foot pedal it's electronic now.
    Looks like the radiator/hydro cooler is stationary versus the C series where you could raise it up and also,I see they've relocated the muffler and exhaust. Looks pretty good from what I can tell.
  4. #24
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    The supertrak 140 I demoed last year, I couldn't tell the difference between the door on the 140 and the one on my cat 297. The salesman calmed it was thicker but it wasn't enough to tell any difference between the two looked like the cat lexan to me but I could be wrong or they forgot to put there supertrak door on it. I know the door on my 297 could take a lick, I was mulching down a 15 in. pine when the head split the tree with the head little over eye level then threw about a 8 in. Diameter piece over two foot long right into the door had so much force it opened the door, but didn't even leave a mark, besides the one in my pants.
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  5. #25
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Ramzee u said u had a cat hm415 head on order. I could find any info on it is it like a fae 175?
    HFM LLC
    251-331-4475
  6. #26
    Platinum Member tonyoz's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Queensland & Far South Coast NSW Australia
    Rayco
    Hey Cat, go to (www.fae-ap.com.au) then search Hydraulic,skid steer.A PDF file is on the left with the info . It's a UML/SSL 175
    CTC Mulching
    I'm going to die without any enemies' in the world cause I will outlive the barstards
  7. #27
    Join Date
    Dec 2010
    Posts
    55
    Central, IL
    3-Cat 299D XHP,1-Cat 299C, Cat 315DL,Cat 315CL,2-Jarraff
    Robbie, Thanks. The door is supposed to be a full 1/2" thick will that suffice? It is alot stiffer than the proto was. The magnet material is great, that will be easy to remove if needed.
    Timberwolf, yes the radiator is stationery, the grating raises on the top now. the hydraulic filter is in the spot of the old muffler.
    Cat, I've been nervous in the C's also. The new door is thicker than the proto was, guessing it had the same as the C on it. The new one is thicker. It will be a couple weeks before I get to mulch with the new one and try out the door. I would guess it to be similar to the 175, I don't have any paper work on it yet, will call my salesman see what I can find out.
    Sorry took so long, late getting in.
  8. #28
    New Member
    Join Date
    Dec 2011
    Posts
    21
    ansonville,nc
    bobcat t870
    looks nice might have to check on buying one
  9. #29
    Join Date
    Apr 2011
    Posts
    64
    NC
    Quote Originally Posted by cat 297c View Post
    Ramzee, just wandering if you had any word on your HM 415 yet ? CAT rep's telling me in order to run my HM 315, special quick coupler adapters will have to be ordered and it will be August before they're are available. Also, I was wondering if this would affect my hydraulic pressure/flow to the head. And also the electric over hydraulic wiring harness "If I understood him right" would also be on hold till August. Just wandering if you or anybody else on here had any info on the matter ???
  10. #30
    Join Date
    Dec 2010
    Posts
    55
    Central, IL
    The 415 is supposed to be on the boat headed this way. don't have a delivery date yet. Seems like my rep told me the adapter kits weren't available but could be ordered through parts. When we were running our hm312 on it we got the bigger couplers and screwed them onto the mulcher hoses so we didn't need the adapters. Cat had put the electric pin connector on when they set up the proto. I'll talk to my rep tomorrow and see what all he knows.
Similar Threads
  1. Cat 299d
    By 05rammer in forum Land Clearing Equipment
    Last Post: 01-31-2013, 06:13 AM
  2. How to convert Cat 2 Brush Hog for Cat 1 Tractor
    By swmich42 in forum Attachments
    Last Post: 04-13-2011, 08:42 AM
  3. More Visitors to the Prairie
    By RobS in forum Photos
    Last Post: 10-07-2008, 05:33 PM
  4. Cat 1 or cat 2
    By curly in forum Kioti Owning/Operating
    Last Post: 09-19-2007, 08:21 AM
  5. How to trap a skunk
    By roxynoodle in forum Related Topics
    Last Post: 10-22-2006, 08:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
