Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
  1. #11
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    Finally got to run my diamond DLR072-C brush on a job for a few hours yesterday cat still hasn't got my high flow plug in yet for my cat 299d xhp so I ran the diamond in low flow the entire time an holy crap I can't wait to see wat this thing will do I high flow. In low flow I cut down a 10in live oak and mulched it up no problem I cut and trimmed along a gas line were my customer plants a food plot he can defently can see from one end to the other now.
    Attached Thumbnails Attached Thumbnails Davco vs Diamond Mower-forumrunner_20120916_090743-png   Davco vs Diamond Mower-forumrunner_20120916_090855-png   Davco vs Diamond Mower-forumrunner_20120916_090951-png
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  2. #12
    Bronze Member Eric H's Avatar
    Join Date
    Nov 2008
    Posts
    68
    Default
    Pretty sure that is designed for low flow only..mi know my davco is not ment to be run on high flow.... Like u said low flow is plenty lol
  3. #13
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    This unit is rated up to 45 gpm, I was also surprised how well it mulched up the material.
    HFM LLC
    251-331-4475
  4. #14
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Here's a picture of the material I processed
    Attached Thumbnails Attached Thumbnails Davco vs Diamond Mower-forumrunner_20120916_143425-png
    HFM LLC
    251-331-4475
  5. #15
    Join Date
    Dec 2010
    Posts
    55
    Central, IL
    3-Cat 299D XHP,1-Cat 299C, Cat 315DL,Cat 315CL,2-Jarraff
    Default Re: Davco vs Diamond Mower
    Cat, Looks good.
  6. #16
    Veteran Member RDrancher's Avatar
    Join Date
    Aug 2011
    Posts
    2,180
    North Texas
    New Holland TC35D, Kubota SVL90-2 CTL
    Looks like the diamond does a nice job. How was it at containing debris without chucking it way out there?
    John
    My Work & Stuff Photo Thread: http://www.tractorbynet.com/forums/p...to-thread.html
    John 14:6
  7. #17
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    It still throws debris pretty far but not as bad as the davcos I've ran in the past.
    HFM LLC
    251-331-4475
  8. #18
    Member RINGPOWERTALLY's Avatar
    Join Date
    Jun 2012
    Posts
    43
    Tallahassee, FL
    1970 John Deere 4020 PS, Kubota M4060
    hey cat, did they not set you up with a jumper to run in XPS and in XHP? or are you only XHP or low?
  9. #19
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Just got my jumper to run the diamond in high flow I hope its xhp. Cat didn't offer just the jumper they only offer it in a kit that includes the bigger hyd. Quick couplers and the jumper that was going to be like 400.00 so my dealership made a jumper for me for nothing they said thanks for buying the machine.
    Hope it is xhp
    HFM LLC
    251-331-4475
  10. #20
    Join Date
    Jun 2012
    Posts
    43
    Tallahassee, FL
    you can run the machine in all 3 modes depending what pins you have grounded, i just got done making a switch harness to put in the cab to switch between XPS, XHP and low flow..... YOU DO NOT WANT TO RUN YOUR DIAMOND IN XHP...... you will regret it no matter what your dealer says....... we just ate a davco motor on a customer demo because someone forgot to switch to XPS....... your motor is only rated for 36 gpm at 3250 psi...... XHP is 38-41 at 4500+ psi........ it builds to much heat and not only derates constantly but will burn the seals out of the motor on the mower. some of the first 299d's where actual incorrectly calibrated at the factor and are putting out over 45gpm at 4700 psi!!!
Similar Threads
  1. Davco Brush Cutter
    By KiotiAcres in forum Construction Equipment
    Last Post: 06-04-2010, 07:05 PM
  2. Davco brush mower
    By redmon in forum Land Clearing Equipment
    Last Post: 05-25-2010, 08:32 PM
  3. Ammbusher,U.S. Mower, Davco
    By Amer Pine Straw in forum Construction Equipment
    Last Post: 08-12-2008, 07:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
