Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. #21
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    O, Paul at diamond said the motor he has on the diamond is set at 40gpm @ 4100psi for my machine. U know wat serial number range the 45gpm @ 4700psi machines are?
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  2. #22
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Ring cat, on my jumper plug the two pins are b an k witch pins put it in xps?
    HFM LLC
    251-331-4475
  3. #23
    Join Date
    Dec 2010
    Posts
    55
    Central, IL
    3-Cat 299D XHP,1-Cat 299C, Cat 315DL,Cat 315CL,2-Jarraff
    Default Re: Davco vs Diamond Mower
    Cat, I believe b-n are xhp, b-k are xps,
  4. #24
    Member RINGPOWERTALLY's Avatar
    Join Date
    Jun 2012
    Posts
    43
    Tallahassee, FL
    1970 John Deere 4020 PS, Kubota M4060
    299D XHP NLC00150-00155, 240-485
    whats your serial, i can look to see if you fall under any of the service bulletins
  5. #25
    Join Date
    Apr 2011
    Posts
    64
    NC
    299D XHP w/HM 415B mulcher
    Quote Originally Posted by RINGPOWERTALLY View Post
    RING, I sent you a PM with my #'s
  6. #26
    Join Date
    Jun 2012
    Posts
    43
    Tallahassee, FL
    Chad, just look and you have all the updates accept the aux Re-Cal, while your in there you might want to get the new turbo guard put on.... its a few hundred dollars of cheap insurance.
  7. #27
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    Sent u a pm
    HFM LLC
    251-331-4475
  8. #28
    New Member
    Join Date
    Feb 2013
    Posts
    4
    Leeds, England
    CAT technician
    Hi all, I just stumbled across this thread while trying to get some info on the CAT HM415 operation. I need to know if the door can be opened independantly of the mulcher head spinning and i thought the best people to ask would be the guys at the levers. Best regards, Danny
  9. #29
    Silver Member McCaskey's Avatar
    Join Date
    Jan 2007
    Posts
    170
    East Aurora, NY
    Although not one of your original choices, I have a Brushwolf 9000HF on order for my RC100. It's 85" wide, two motors and high flow. Awaiting delivery.
    2006 ASV RC100, Loftness Carbide Cutter, Erskine snowblower, Brushwolf 9000HF, 2003 New Holland TN65, 2014 Kubota RTV-X900, 1985 Jacobsen HR15, 1981 John Deere 400, 1979 Ford 7700, 1958 Wife
  10. #30
    Join Date
    Jan 2007
    Posts
    170
    East Aurora, NY
    Brushwolf delivered. Only 4 months until something grows that needs cutting. It's a lot of weight out front, I hope it doesn't cause the ASV arms to fracture over time.
    Anyone got experience to share with a 85" high flow Brushwolf?
    Davco vs Diamond Mower-wp_20130304_008-jpg Davco vs Diamond Mower-wp_20130304_011-jpg
Similar Threads
  1. wanted used Davco mower
    By redmon in forum Wanted Ads
    Last Post: 05-18-2011, 11:11 PM
  2. Davco Brush Cutter
    By KiotiAcres in forum Construction Equipment
    Last Post: 06-04-2010, 08:05 PM
  3. Davco brush mower
    By redmon in forum Land Clearing Equipment
    Last Post: 05-25-2010, 09:32 PM
  4. Looking to buy a used Davco
    By QwikDraw in forum Wanted Ads
    Last Post: 05-01-2010, 01:46 AM
  5. Ammbusher,U.S. Mower, Davco
    By Amer Pine Straw in forum Construction Equipment
    Last Post: 08-12-2008, 08:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
