Looking for advice on cleaning up a clear cut pine plantation
   / Looking for advice on cleaning up a clear cut pine plantation #11
Its probaly going to take a lot longer for them to rot than you wanna wait to be able to pull out with a front loader. A small dozer would be your quickest soulution for the size stumps you mentioned. Maybe clean it up yourself with your tractor then get somebody to pop the stumps for you.
   / Looking for advice on cleaning up a clear cut pine plantation #12
Why worry about the stumps if you are going to replant in pine?
MarkV
I sort of assumed that would be the answer; pine stumps do seem to stick around forever.
Am I at least on the right track with my idea of a 40-50hp tractor with grapple for clean up? I know it may be slow, but (1) I'm cheap, and (2) I'm afrad a shear and rake will be hard on the topsoil in hilly sections. And to be honest, I'm wanting to do as much of this myself as I can.
MarkV
In the areas to be replanted in pine I'm only planning to clean the slash out and I will not worry about the stumps. But I'm also planning to keep some of the area open and will need to get the stumps out so I can disc.
   / Looking for advice on cleaning up a clear cut pine plantation #14
It will be slow, but very relaxing and rewarding work to do it yourself. Enjoy your property if you decide to purchase it.
   / Looking for advice on cleaning up a clear cut pine plantation #15
If I were you, I'd either rent a very large excavator and just use it to pop stumps out for the week. You can always go back with a tractor with grapple of your choice and move it to a burn pile. You can use the same tractor to try to push some of dirt back in hole. If you happen not to be able to pull all the stumps out- renting or buying a 3 pt stump grinder would be my choice to finish cleaning up rest of the stumps so you would have nothing left to burn. You would move some of slash to the stump burn pile and go at it. This would be the cheapest option and good personal therapy :thumbsup:
   / Looking for advice on cleaning up a clear cut pine plantation #16
If you have time and small budget those pine stumps will rot and disappear in five to six years. Want pasture? Control burn will sweeten the soil for vigorous grass. Just get the stumps low enough so your brush hog can pass over the stump. You will have beautiful pasture by the third summer.
   / Looking for advice on cleaning up a clear cut pine plantation #17
For 12"-14" stumps, and slash leftover from logging, you'd be amazed at how much you can cleanup with a setup like mine....
I can grind a 12" stump a foot below ground level in no time. How high are the stumps?
If I were in your situation, and the stumps really are that small, and I wanted to do it myself, I'd use just the setup I have now with the exception of if I were buying a tractor, and didn't already have one, I'd buy the next size up from mine and somewhere around 60PTO hp. Also, a skid plate of some sort would be almost required for logging cleanup.
I've done a lot of similar work as you describe, but on a much smaller scale, no where near 80 acres, but that isn't to say it can't be done, it would just take a long time.
If you want to make a lot of progress with affordable equipment, and minimal impact on the land, then the grapple setup on a good size tractor, and stump grinder on the back, would really do a lot for you.
unclebuck1
Well, I signed a purchase agreement yesterday and I'm closing on the 31st, so these questions aren't so abstract now.
Lots of good advice so far, but this one caught my eye:
will pine stumps in the 12-14" range (small saw logs) really rot to ground level in 5-6 years? As I mentioned in my first post the land was logged last spring- say 18 months ago- and if this is correct I might let time do the work of an excavator or stump grinder.
   / Looking for advice on cleaning up a clear cut pine plantation #19
They won't rot to ground level, but you can cut them to ground level with your chainsaw.....Or a 3pt hitch turbosaw.
Not sure what the soil is like where you are, but where I am, 12"-14" pine stumps last a lot longer than 5 yrs, no way will they be rotted out by then.
   / Looking for advice on cleaning up a clear cut pine plantation #20
Around here- that is standard- though sometimes they chip everything left behind nd it goes to the papermill. The slash is your ground nutrition- it rots in and fertilizes the ground. Here after clear cuts they plant saplings by hand- plugs carrying them in bags slung over their shoulder- low wage summer job. The stumps and all of it rots in time. Wild Raspberries make the first comeback. The dead stuff on the ground and the growing stuff helps to hold the moisture and keep the forest from drying out in the heat of the sun- and everything dying. 15-30 year cycle for pulpwood - spruce. Large clearcuts look like wasteland.
Good luck.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A51248)
UNUSED WOLVERINE...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
