Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,528
    Cumberland Plateau, TN
    Bobcat CT225
    Default Re: Adding a case drain to excavator
    Case drain line needs to have minimum back pressure possible. It is fine to run it through the oil cooler if cooler has no pressure drop acorss it, or less than 5 psi. Case drain should also have a filter in case of motor bearing failure or internal motor failure, to keep the debris from dumping into the reservoir and contaminating the entire hydraulic system. Northern Tool (among others) has 10 micron return fitlers for about $25 which will handle upto 20 GPM. Case drain line normally will only be running about 10% of the pump flow to the motor. So a 20 GPM pump to motor flow will only be around 2 GPM case drain flow. If you don't go through the cooler, dump it into the tank below the fuild level and make sure it is as far away from the suction outlet as possible. Dumping into the suction or close to it can cause a swirl action that could cause areation to oil going into the pump.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  2. #12
    Platinum Member tonyoz's Avatar
    Join Date
    Sep 2009
    Posts
    559
    Queensland & Far South Coast NSW Australia
    Rayco
    Refer to the way your PT100 is plumbed. Heat is the biggest cause of failure in mulching equipment especialy in open loop hydraulics which is what you have. At the end of the day it's your machine and your money your sending, just hope you spend it wisely and once.
    CTC Mulching
    I'm going to die without any enemies' in the world cause I will outlive the barstards
  3. #13
    Bronze Member ALittleDirtWontHurt's Avatar
    Join Date
    Sep 2012
    Posts
    78
    VIRGINIA
    Terex PT110 Forestry, New Holland LT185b, New Holland TC33, Kubota KX080, Terex PT30, ASV RC50, Rayco C140, Polaris ATP 500
    Thanks for the help so far.....here's what I'm working with. Looks like that top access lid may be the way to go. Adding a case drain to excavator-20121229_152939-jpgAdding a case drain to excavator-20121229_152944-jpg
  4. #14
    Join Date
    Jul 2011
    Posts
    66
    Spokane WA
    Terex, Fecon,
    Give Ed in our shop a call he has done a couple of 80's and he will be able to walk you through the case drain.
    NWTEREX
    www.fmisales.com
    509-927-4071
  5. #15
    Join Date
    Jan 2007
    Posts
    125
    Roxton Falls, QC
    Any, as long as there's a DENIS CIMAF head on it ;)
    Or call Gilles, our tech manager (toll free 877-279-2300). Even if it's not for running one of our head, he'll help you no charge. This is our way to say thank you for your good comments on Eric H's post this past November. (Cat 297c, if you read this, don't worry, you will not be forgotten either )
    Frederic Denis
    DENIS CIMAF Inc.
    www.deniscimaf.com
  6. #16
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    Quote Originally Posted by deniscimafinc View Post
    Just give me a Cimaf Generation 3 180E for my CAT 299D XHP an we'll call it even!!!!!!
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  7. #17
    Join Date
    Jan 2007
    Posts
    125
    Roxton Falls, QC
    Quote Originally Posted by cat 297c View Post
    I'll start giving good comments on the Audi R8, if that can land one in my parkway.
    Frederic Denis
    DENIS CIMAF Inc.
    www.deniscimaf.com
  8. #18
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    I hear ya!!!
    HFM LLC
    251-331-4475
  9. #19
    Join Date
    Feb 2008
    Posts
    1,854
    Orstraya , Ex convict stock , G'day .
    As SS said , the case drain must be below the fluid level in the tank . Most lines going into the tank below the fluid level are drains , a "TEE" into one of these at the tank works well and eliminates the need for welding and drilling .
  10. #20
    Join Date
    Sep 2012
    Posts
    78
    VIRGINIA
    It appears my tank is pressurized. Would this affect anything installing the line coming in through the top of the tank but returning below the fluid level?
Similar Threads
  1. Case Drain ?
    By DIRTROAD in forum Land Clearing Equipment
    Last Post: 11-04-2010, 08:05 AM
  2. Case CK-28 Excavator
    By Localmotion in forum Case-IH
    Last Post: 06-17-2009, 04:50 PM
  3. case-poclain excavator purchase
    By DrRick in forum Construction Equipment
    Last Post: 03-13-2007, 12:45 AM
  4. adding a garage drain
    By Moon in forum Rural Living
    Last Post: 04-27-2005, 02:49 PM
  5. Case 125 excavator!
    By jamieac in forum Construction Equipment
    Last Post: 04-27-2003, 02:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
