Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Platinum Member bikerdib's Avatar
    Join Date
    May 2010
    Posts
    644
    Texas
    Kubota B3300SU
    Default Re: Pulling out trees?
    A couple of years ago I cleared about an acre full of oak and chinese tallow. Some of the trees had trunks up to 16 inches diameter but none were more than 25 to 30 feet tall. On the largest ones I did a circle around the tree with a subsoiler to cut as many roots as possible. I did the climb the ladder thing and hooked a chain cinch about 10 to 12 feet above the ground. I then used 40 feet of chain to the drawbar of the tractor (never hook above the axle). To protect myself as much as possible I hung a weight on the chain half way between me and the tractor. I also mounted some horse panel to the roll bar (which I decided to keep in place for mowing and other things) Horse panel is made up of 1/4 inch steel rod with a 2 inch by 4 inch pattern. I cut it to size and clamped it in place on the back of the roll bar with large hose clamps.
    '12 John Deere X320; '10 Kubota B3300SU with 504 loader with Kubota Quick Attach, Home built forklift carrier that fits on the FEL or 3 point, Landpride SGC0660 grapple, 3 point grader blade, 3 point dump bucket, BH77 backhoe with BXpanded quick attach for buckets, BXpanded trenching bucket, BXpanded ripper, 3 point subsoiler, Landpride RCR 1860 rotary cutter, 3 point log splitter, 3pt quich hitch, Pat's Easy Change, and hydraulic top link
  2. #22
    Gold Member Grayson Klassen's Avatar
    Join Date
    Mar 2011
    Posts
    271
    Fort St John, BC
    John Deere 4020
    Not sure why no one has mentioned a chainsaw to cut down the tree to manageble height first. Then for stumps I agree excavator with a thumb does the cleanest job.
    Grayson Klassen
    Fort St John, BC, Canada
    JD4020
    JD148 FEL
  3. #23
    Silver Member MWRR's Avatar
    Join Date
    Jan 2011
    Posts
    146
    East Central Illinois
    John Deere 5105M & IH Farmall 544
    I use my old 580B backhoe. It's not the fastest way of removing a tree but I haven't found a tree I could take down......now moving out of the hole was a challenge. I had to dig a ramp out of the hole and roll the stump out after I had removed the tree portion.
    MWRR
    Illinois, 180 acres, 80 acres hay, cattle, JD 5105M,IH-Farmall 544, Kuhn 700 GMD HDII, Case 580B, JD 535 Baler, MF 124.
  4. #24
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,905
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by CA Grown View Post
    I'm wondering if there's a better way to pull out trees than wrapping a chain around them and yanking them out with a tractor.
    Trees are various citrus, almond, walnut and grapes.
    There's gotta be an easier way to get em out, right?
    My easy way is a stump bucket.
    Pulling out trees?-p9290029-jpgPulling out trees?-p9290035-jpgPulling out trees?-p9290037-jpg
Similar Threads
  1. pulling trees over
    By Scotty Dive in forum Land Clearing Equipment
    Last Post: 07-08-2012, 08:43 PM
  2. Pulling over trees...
    By SuperCobra in forum Owning/Operating
    Last Post: 05-29-2012, 02:53 PM
  3. Pulling Trees and Saplings
    By SandburRanch in forum Land Clearing Equipment
    Last Post: 12-04-2010, 05:22 PM
  4. Pulling vines out of trees
    By Will in forum Owning/Operating
    Last Post: 03-17-2006, 06:09 PM
  5. Pulling Trees Down With The Tractor
    By TBAR in forum Safety
    Last Post: 03-09-2004, 02:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
