Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Platinum Member deezler's Avatar
    Join Date
    Jan 2012
    Posts
    694
    Southeast MI
    Cub Cadet 7305
    Default Re: Anyone use a Brush Grubber?
    I have the smallest, baby brush grubber. It works great for pulling trees and shrubs up to 3" dia. But you really need to use it in a two man team, taking turns between being the grubber b!tch who connects the grubber and resets it onto the next tree after you get one out.
    Quote Originally Posted by Dan Hunter View Post
    I had one of those. It was very susceptible to bending. At one point, it broke a shrub I was pulling using a chain and it shot back and landed on the hood denting it and chipping the windshield of my truck. I therefore would not recommend one.
    Whoa. You must have been pulling out something massive to get that much tension on your line. I can't really understand this though. I've had my grubber slip off the tree many times, and each time it just flopped with a dull thud onto the ground. Were you pulling in reverse?
  2. #12
    Gold Member
    Join Date
    Nov 2011
    Posts
    496
    Enid, OK
    2012 John Deere 3720 eHydro
    Quote Originally Posted by mvwicker View Post
    Ouch! which size grubber did you have?
    I'm not sure; let me go out and measure the dent pattern in the hood.
  3. #13
    Gold Member
    Join Date
    Nov 2011
    Posts
    496
    Enid, OK
    Quote Originally Posted by deezler View Post
    It was a 2.5" shrub at the base. I'm not sure what they are but they're very ugly and tough. I'd pulled a bunch out before it broke the shrub in half while I was backing with a straightened heavy chain. Since the chain wasn't twisted and it had slipped off and just dropped before, I was somewhat surprised. Backing...I'd rather not but half my neck is fused and I go out of my way to place unnecessary demands on the remaining discs. Geez, the tractor has a backup camera.
  4. #14
    Join Date
    Jan 2012
    Posts
    694
    Southeast MI
    Cub Cadet 7305
    In any case, sorry to hear about that, that sucks.
  5. #15
    Gold Member
    Join Date
    Nov 2011
    Posts
    496
    Enid, OK
    Not really. Now the hood looks as bad as the rest of the truck. And the windscreen? I don't see that well anymore anyway so I don't notice it unless I'm looking for it which is never.
  6. #16
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,729
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    I'm considering getting a Brush Grubber Xtreme to pull out some shrubs (clumps of 5 or so 1" canes) and saplings (2-3" hardwood, 3-5" pine and cedar). One possibility is to use this device:
    BrushGrubber | Brush Grubber Xtreme
    Does anyone here have experience with it that you would like to share?
    I got the Xtreme Plus because of the 4500 pound lift rating on my Versahandler. I wanted it to pull broken roots left from popping trees out with the stump bucket.
    Anyone use a Brush Grubber?-p2180004-jpg
    A 3" trunk partially cut with the rotary mower, was pulled easily.
    Hooked on.
    Anyone use a Brush Grubber?-p2180034-jpg
    Moving up.
    Anyone use a Brush Grubber?-p2180036-jpg
    Hard to see, but the longest root was about 12' long.
    Anyone use a Brush Grubber?-p2180037-jpg
    The Plus is heavy and hard to remove from the pulled stump, I will take a small prybar next time to pry the pads out of the stump. Standing on one handle while pulling up on the other handle would open it after pulling roots, but sometimes had to pry the root off of the other pad.
    But it does work! Just wore me out! But I am old and worn out anyway
  7. #17
    Join Date
    Feb 2013
    Posts
    7,729
    Meridian, OK
    I also bought the hand operated one, for pulling prickly pear cactus.Anyone use a Brush Grubber?-p2180026-jpgAnyone use a Brush Grubber?-p2180027-jpgAnyone use a Brush Grubber?-p2180029-jpgAnyone use a Brush Grubber?-p2180030-jpgAnyone use a Brush Grubber?-p2180031-jpg
    I pulled some small cedars, see the roots.
    Anyone use a Brush Grubber?-p2180028-jpg
    If you get a hold of something you can't pull with both hands on it, it doesn't slip it just stays there listening to you grunt and groan!
  8. #18
    Member
    Join Date
    Jan 2004
    Posts
    46
    Lakeland Shores, Mn
    JD 4210 eHydro, F725 w/54" deck
    I use a BG8 and it works great. The only downside is it gets rather heavy after a hour or so of use and opening the spring-loaded jaws becomes more difficult.
  9. #19
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Just bought the extreme for 89.00 from forestry supplies
    Murph
  10. #20
    Silver Member Brushhill dave's Avatar
    Join Date
    Jun 2011
    Posts
    207
    central alberta
    kubota 2360,Ford 4610,111jd,gt200 husky
    Default
    Does anybody know of a supplier in Canada for this device? I have lots of stumping to get done
Similar Threads
  1. B2920 and Brush Grubber
    By Watercarving in forum Kubota Owning/Operating
    Last Post: 12-23-2011, 09:40 AM
  2. Brush Grubber?
    By saltbranch in forum Build-It Yourself
    Last Post: 03-17-2011, 07:09 PM
  3. Trying out a Brush Grubber
    By nikdfish in forum Attachments
    Last Post: 01-28-2011, 10:54 PM
  4. Brush Grubber
    By Bill Barrett in forum Attachments
    Last Post: 10-03-2008, 06:57 PM
  5. Brush Grubber - review of
    By ragkar in forum Attachments
    Last Post: 04-21-2008, 09:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
