Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    Oct 2010
    Posts
    13
    Zebulon, GA
    Default Anyone in Georgia who has a forestry mulcher? Questions about clearing land
    I posted this question on the Bobcat forum also but just realized this is probably the more appropriate forum to ask this. I have 104 acres that were clear cut 6-7 years ago and need about 60-65 acres of it thinned from around 2000 trees/acre to 600 trees/acre. This was originally a loblolly pine farm but I now have a mixture of these and other trees including sweet gum, privet hedge and other junk. I am also including pictures of my land to show how dense the trees are. I am wondering if I can use my Brown Tree cutter adapted to a Bobcat to clear this with or if I should consider hiring someone to mulch it and/or rent a mulcher. I have a neighbor who will let me borrow his Bobcat S250 to use but I don't know if it is too small for this type of use or not or if I should consider renting a larger unit. It has standard flow hydraulics unfortunately. Here is my original post..
    I have a Brown Tree Cutter that I tried to use with a Ford 5000 tractor but when I backed into the trees, I could only go about 10-15 feet before the pine trees "bunched up" behind the cutter and it created enough drag to cause my tractor wheels to spin. It was suggested to me today that I perhaps use a Bobcat to 3 point hitch adapter with a hydraulic motor to allow the use of the Brown Tree Cutter on the front of the Bobcat. I found one adapter here from searching the forum
    3 PT. Hitch Adaptor without Hyraulic Unit
    but don't know if it is beefy enough to support this tree cutter. This thing is pretty heavy and is quite a load for my Ford 5000. If I could get it high enough off the ground so I could move it up and down to mulch the pines and keep it level at the same time it might just work however. I can supposedly cut up to 5 inch trees with this thing but don't want to try that. It mows down the small pines just fine but after they start bunching up I can't go any further. I don't know how big of a hydraulic motor it would take to drive this thing also or if my standard flow would run it. Here is a picture of the tree cutter. It is an older model from the late 90's I was told by Brown (90 hp gearbox). The newer units have 165 hp gearboxes. Most of the pines I want to remove are in the 2-3 inch range. Anything larger than that I would like to save.
    Anyone in Georgia who has a forestry mulcher?  Questions about clearing land-brown_cuttera-jpgAnyone in Georgia who has a forestry mulcher?  Questions about clearing land-trees5a-jpgAnyone in Georgia who has a forestry mulcher?  Questions about clearing land-trees4a-jpgAnyone in Georgia who has a forestry mulcher?  Questions about clearing land-trees3a-jpgAnyone in Georgia who has a forestry mulcher?  Questions about clearing land-trees1a-jpgAnyone in Georgia who has a forestry mulcher?  Questions about clearing land-air2a-jpgAnyone in Georgia who has a forestry mulcher?  Questions about clearing land-air1a-jpgAnyone in Georgia who has a forestry mulcher?  Questions about clearing land-treesa-jpg
  2. #2
    Gold Member
    Join Date
    Jul 2004
    Posts
    345
    Cartersville (NW) Georgia
    John Deere 1025r TLB
    Default Re: Anyone in Georgia who has a forestry mulcher? Questions about clearing land
    I'll send my brother a link to your post. He has an erosion control company and some wicked cutter on a big Bobcat that should do the job, problem is he ain't cheap.
    '13 JD 1025r TLB
    60D MMM w/ electric over hydraulic independent lift
    Custom Seat Springs (no more bottoming out)
    Single Point Quick Disconnect
    180* Thermostat
    Artillian Forks (42")
    Ken's Bolt On Hooks
    Omni Transformer
    Kubota ZD326H, 72" deck, Qwikchute OCDC
  3. #3
    Gold Member cat 297c's Avatar
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Cat 299D XHP, Cat 297c, Rayco C140
    Default
    Quote Originally Posted by PsRumors View Post
    No one running a decent brush cutting/mulching business is going to be cheap we burn tons of fuel, all the hyd. fluild grease, teeth on a small mulcher will run $3000.00 easy, wear an tear on the machine due to just running the machine wide open all day long 10 plus hrs a day. Just to name a few
    HFM LLC
    251-331-4475
    lifescapes-forestry-mulching.com
  4. #4
    Super Member
    Join Date
    Apr 2000
    Posts
    5,673
    Cedartown, Ga and N. Ga mountains
    1998 Kubota B21, 2005 Kubota L39
    Have you talked to the Ga. Forestry Service about a controlled burn. It looks like it would be beneficial for at least part of your property.
    MarkV
  5. #5
    New Member
    Join Date
    Nov 2010
    Posts
    10
    Quote Originally Posted by gdk771 View Post
    Your neigbors Bobcat will run a mulcher if it has high flow hydaulic ( 30GPM @3000PSI or more) and it must have a Lexan winshield for operator protection. 3-5 inch is ideal for a mulcher on a skid steer. New mulchers run in the mid $25,000 range. I have a refurbished one for approx. $15,000. Give me a call--if a mulcher does not make sense I beleive I could hook you up with a contarctor in your area. 513-284-8990 thanks Jim
  6. #6
    Gold Member fishfactor's Avatar
    Join Date
    Aug 2010
    Posts
    462
    Monroe, NC
    (2) 2014 CAT 299DXHP / FECON
    We just finished 45 acres that looked a lot like yours, except we cleared everything and the landowner started over, planting pines. Mulching will give you a good result, but you will pull your hair out in a skid steer on that many acres. We could only do 2-3 acres/day with our T320, but did 8-9/day with the gyro trac. A larger machine may cost a lot more per hour, but will be more economical overall. Another option would be manually. Around here, there are crews of guys that come in with brush saws and just cut and let the trees fall. It looks horrible, but things eventually rot.
    There is a good chance we will be about 30 miles from you this weekend if you would like for us to come by and give a estimate.
    No matter what anyone tells you, old fencing, cable, and farm implements that are in the middle of the woods are not your friends!
    Colby
    S & P Land Services
  7. #7
    New Member
    Join Date
    Oct 2010
    Posts
    13
    Zebulon, GA
    Thanks for the replies everyone. I'll touch base with fishfactor and Jim. Thanks cat297c also for your help and advice. Unfortunately the Bobcat is a standard flow hydraulic unit. MarkV I have been in touch with GA forestry, great bunch of folks. My district forester came down and prepared for me a detailed land use plan along with maps. He said if I thin the pines to around 500-600/acre the ones left will really take off and make a fine stand of trees. He suggested controlled burning after thinning. I really wish the previous owner had taken better care of this land but he ran into money problems and just stripped the timber before selling it.
  8. #8
    Join Date
    Mar 2009
    Posts
    413
    Semmes, Alabama
    Default
    No problem
    HFM LLC
    251-331-4475
  9. #9
    New Member
    Join Date
    May 2012
    Posts
    6
    jasper,tn
    mf 35, JD5083,mf271,mf1035
    I think you need a bigger tractor, to run over the trees, I run a brown on a 130hp Massey or a ts110 Ford. run over the trees in forward only problem is it is ruff on tires. it will leave some small stumps that are ruff on tires..
  10. #10
    Gold Member Degolyerent's Avatar
    Join Date
    Nov 2010
    Posts
    439
    Default
    You might try removing the tail wheel assembly to cut down on the weight and shorten the top link to get it up higher.
Similar Threads
  1. Clearing water access land questions...
    By acs55812 in forum Land Clearing Equipment
    Last Post: 09-06-2011, 11:14 AM
  2. New to me Kubota B2100 and some land clearing questions
    By cnice37 in forum Kubota Owning/Operating
    Last Post: 05-04-2011, 11:45 PM
  3. Georgia land clearing
    By Robert Kemp in forum New Member Introductions
    Last Post: 05-01-2010, 03:48 PM
  4. Newbie Land Clearing Questions
    By danielread in forum Buying/Pricing/Comparisons
    Last Post: 02-23-2008, 07:16 PM
  5. Questions on clearing land
    By rlee6 in forum Projects
    Last Post: 10-19-2004, 12:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
