AKFISH, YEIIOWDOG AND TONY thanks again for your input. If you don't mind I'd like to pick your brains a bit more. Something I left out..... I've been wheelchair bound for 26 years now due to an on the job accident. Use to be a welder. I've been able to stand a bit and take a couple of steps if I can hold on to something sturdy. Which is how I get on my tractor. Step up on a wooden box and lift my self up onto tractor with upper body. Not looking for sympathy but understanding of how to upgrade to equipment. Therefore skidsteer is out .... Can't get in the darn things.bigger tractors .... To darn high. Maybe 5085. I've seen some for sale that are low profile by changing rims and using industrial tires (shorter lugs). All this to allow me to get up in the tractor. And I am now 63. I hope to do this another 10 years. Mowing lots / pastures , spreading dirt is probably 60 % of my work. Brush clearing 40% but hope to pick it up. So please reconsider your experience is invaluable. AKFISH your 5075 using the mulcher what gear could you run in mulching 1"to 3" brush? Could you run it in forward gears ? Anyone else please give me your input. Thanks again
I applaud yur grit, sir. You sic 'em - for as long as you can!
Yes, I ran the mulcher in forward and reverse gears. Usually in the first (2) lowest gears - A1 and A2.
My experience in really thick brush was... I wished I'd bought the creeper transmission option! You really want those teeth to grind and grind. Even at 1.1-1.2mph the tractor would bog down and not do a good job mulching. Required 4-5 passes to really grind things up and bury the woody material into the soil.
Couple of observations - JD makes a low profile cab tractor for tree farms, nut farms and vineyards. You can get them with lower profile R4 tires that are heavier duty (puncture resistant) with higher ply rating than the R1 tires. Getting in and out of the cab on those machines would be easier than my 5075M with 30 inch tires. (It's a step up to just reach the 2-step rail - I'm 65...)
However, the powReverser transmission requires using the clutch to start the tractor and place/remove the machine from park. And, to change ranges and forward gears, you need the clutch.
I also own a cab model, JD 4720 (66hp) that is eHydro. It will run my MX-8 brush hog mower that will tackle 1"-3" brush. I leave the loader and bucket on with that mower....LOL! Smaller cab, don't like the AC nearly as good as my 75M, though. The 400CX loader will pick 2,000lb bags of fertilizer but you better watch the rear-end... And go slow. That said, just mowing the brush doesn't really "clear" the ground. There's the left-over stumps and woody slash. That's where the Meri-Crusher would really shine cause it would incorporate the leftover slash, etc. down into the soil leaving a mostly smooth seed bed.
It might be worth investigating a "hand clutch" option with your dealer. Lot's of folk's that have been in the "wrong place at the right time" and had their life forever changed!
So, the manufacturer's have made adjustments based on that reality.
Best of luck.
