Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    New Member
    Join Date
    Dec 2012
    Posts
    15
    Near Great Basin Nat Park, Baker, NV
    9540 Kubota, 30hp New Holland
    Default Re: What about yard waste?
    What about yard waste?-03-compost-pile.jpgWhat about yard waste?-01-brush.jpgWhat about yard waste?-02-gone.jpg I do about the same.. grind it up, pile it, rototill it into the garden in the spring... works perfect
  2. #12
    Veteran Member grnspot110's Avatar
    Join Date
    May 2007
    Posts
    1,007
    MO
    John Deere 790, 420, 314, 317 "Special", "L/60" Custom & 70 I
    For the leaves & garden waste to compost:
    Merry Mac, 5 HP Briggs, screen removed so it doesn't plug with green plants. I gave $67 for it off ebay!
    For sticks & branches for mulch:
    $450 for it off CL (about 1/2 new price), 10 HP Briggs, handles up to 3" (better be pretty straight!), 2" is more realistic! Anything bigger gets cut up for firewood for the shop. ~~ grnspot
  3. #13
    Join Date
    Aug 2012
    Posts
    955
    Hartford, SD
    Kubota L3400F
    I used to pile my bagged grass in a wire enclosure by the yard. I would periodically add a little water and the grass would really settle dut to decomposition. At the end of the process I had a large pile of indistinguishable from cow crap both in color and smell. I essentially cut out the cow from the process but ended in the same place.
  4. #14
    New Member
    Join Date
    Dec 2012
    Posts
    15
    Yuppers... add some steer or cow crap to get the best cellulose enzymes out there... like sourdough
  5. #15
    New Member
    Join Date
    Dec 2012
    Posts
    15
    I think the Mac is a later version of the old Sears models. The best small grinders! I think the whining public forced them to add the no-throwback chute... incidentally making it much harder to feed. I too took out the counter-combs to get thru-put, only adding them when I use it to pulp apples and pears when we make cider.
    The older ones had a metal chute that dropped straight down to let stuff be raked in. The one in the pictures has a plastic one that somewhat restricts the pieces that tend to fly back out... The older ones also had a ring with 4 stubs sticking out about 3/4" where the chute bolts to the body.... that held back the in-feed so that the wheel got a couple more whacks before it got into the chamber... it shredded better.
    Hardfacing the ends of the little hammers and balancing them did wonders too.
    Great tool.
    What about yard waste?-old-sears-1.jpgWhat about yard waste?-old-sears-2.jpg
  6. #16
    Veteran Member 1bush2hog's Avatar
    Join Date
    Jul 2003
    Posts
    1,034
    Georgia
    NH TN75
    Quote Originally Posted by danielpw View Post
    Great tool.
    Click image for larger version.
Name:	Old Sears 1.JPG
ID:	292617Click image for larger version.
Name:	Old Sears 2.JPG
    Huh. I missed something here. Yard waste is put into
    the back corner of the property and depending on the H O a bucket or shovel of dirt can expedite the decomposition process. Not rocket science. Throw in some leftover greens and some coffee grounds to round it out. Shake and bake or turn and burn
    As iron sharpens iron, so one man sharpens another. (Proverbs 27:17)
  7. #17
    New Member
    Join Date
    Dec 2012
    Posts
    15
    True, if you are not in a hurry. Composting is technically defined as accelerated decomposition. If I want to incorporate those prunings into my garden in the spring I must make more surface area available to the bugs that do the decomposition, with enough mass and insulation for the meso and thermophilic bugs to supply the heat to make the decomposer food web happy... so fine particle size produced by shredding is imperative for the composting process to work... natural science.
  8. #18
    Veteran Member Combustix's Avatar
    Join Date
    May 2011
    Posts
    1,460
    NW WA
    Kubota B2710
    Default
    If I don't burn it it goes into a cold pile or one of my two hot piles. Great stuff for the garden front lawn or filling holes and seeding.
Similar Threads
  1. Waste Oil
    By TomG in forum Rural Living
    Last Post: 12-01-2012, 10:03 AM
  2. Back Yard Waste Oil Collection System
    By Gordon Gould in forum Owning/Operating
    Last Post: 09-18-2011, 02:36 PM
  3. what a waste!
    By Steve C in forum Attachments
    Last Post: 03-12-2010, 12:36 PM
  4. can i burn my waste oil somehow?
    By escavader in forum Oil, Fuel & Lubricants
    Last Post: 06-19-2008, 06:43 AM
  5. Don't waste your money
    By WhyNot in forum Related Topics
    Last Post: 02-19-2006, 09:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
