Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Join Date
    Mar 2012
    Posts
    202
    Taylorsville, GA
    3000 Ford 66' 260A International Backhoe
    Default Re: Pulling T-posts
    This seems like a good idea and cheap to build. Add to your FEL.
    You might figure a way to get the puller to release the post by lowering it to the ground and let the post fall to the side then go back and pick up all the posts??
    http://www.tractorbynet.com/forums/b...=t+post+puller
    I've got a cutting torch and a welder sooo YEAH it'll fit!!
  2. #12
    Veteran Member bullbreaker's Avatar
    Join Date
    Mar 2009
    Posts
    2,355
    Southwest,Florida
    Kubota L3400dt,John Deere gt235
    Quote Originally Posted by Soundguy View Post
    they make 1 man, no exit tractor setups for pulling tpost if you have a loader.
    http://www.tractorbynet.com/forums/a...er-anyone.html
    Heres what Soundguy is refering too . Can't tell you how good it works haven't used mine yet. Also there are video's on YouTube demonstrateing this tool. Can also mount to PHD tube or boom pole. Paid $ 2.04 for mine on clearance origignal price was like $69.99 (yikes-) Read whole thread it will lead you to links on YT.
    Boone
    2 CHRONICLES 7 : 14 (KJV)
  3. #13
    Veteran Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    1,555
    Cumberland Plateau, TN
    Bobcat CT225
    Quote Originally Posted by Steave View Post
    I've used that gadet number of times since posting that. If I have a helper I'll hang off the bucket so helper can slip it over the post the take the post out and put it in bucket after I pull it. When by myself I hook on my quick hitch (top hook), back up to the post and get off the tractor to slip it on and run te 3pt standing on the ground. The take the post out and toss it down the line close to next post, back up and pull that one then put 2 posts in the loader with only 1 trip to front of the tractor.
    It was mentioned here to scrap the posts. I don't know what shape they are in but around here used steel posts will bring $2.00 ea if straight and have some paint left on them. New are around $5.00.
    Rolling up old barbed wire: Do you have an old steel barrel, wrap all the strands around the barrel then roll the barrel back over the wire to wrap it up then sell barrel with wire on it. Just a thought.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  4. #14
    Platinum Member RDrancher's Avatar
    Join Date
    Aug 2011
    Posts
    968
    Sanger, Texas
    NH
    I use my Ratchet Rake. The first time I tried it I pulled over 60 posts as quick as I could move to the next post. Only bent up the first two getting the right angle.
    Yesterday I hit ROCK BOTTOM.....Today I started to DIG..
    My Work & Stuff Photo Thread: http://www.tractorbynet.com/forums/p...to-thread.html
  5. #15
    Silver Member DeeDubya's Avatar
    Join Date
    May 2011
    Posts
    184
    San Marcos, TX
    Branson 2910i
    Thanks for some good solutions. Most of these posts are in rock. I don't think holes were drilled for them but just driven into cracks between the rocks. Most are not pullable by hand no matter how much you wiggle them first. The bucket & chain is working OK for now but I do like bcp's idea. I just might waste too much time trying to get the post in the hole. My tractor's not a hydrostatic.
    DW
    "You can easily judge the character of a man by how he treats those who can do nothing for him."
    ~ James D. Miles
  6. #16
    Join Date
    Sep 2012
    Posts
    171
    Ottawa Ontario
    Kubota B3300SU
    If you are welding the box to the side of the bucket, put it on the right side, not the left. With the FEL controls on the right so it will be much easier to see what you are doing while trying to do it without having to try to see one side of the tractor and run controls on the other.
Similar Threads
  1. Pulling out posts etc.
    By Task in forum Attachments
    Last Post: 02-18-2010, 08:50 AM
  2. Pulling posts
    By wroughtn_harv in forum Build-It Yourself
    Last Post: 04-25-2004, 07:33 PM
  3. Pulling posts
    By wroughtn_harv in forum Attachments
    Last Post: 02-08-2003, 11:47 AM
  4. Pulling posts
    By GrantMO in forum Kubota Owning/Operating
    Last Post: 09-10-2001, 09:39 PM
  5. Pulling Posts
    By mlp in forum Kubota Owning/Operating
    Last Post: 09-02-2001, 10:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
