Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 74
  1. #21
    Elite Member
    Join Date
    Jul 2007
    Posts
    3,221
    Default Re: Troy-Bilt Horse ID
    CR172, 17566 is not a part number in my 1982 parts catalog for the Horse Model. Could it be your tiller serial number? There are two locations to look for it. (BTW, Troy Bilt sold an optional snow plow as an accessory. )
    Dennis, TH-1001-1 is also not a part number in my parts catalog. With it being cast, it might be a part number?
    The controls on mine are limited to a throttle, the hi-low range lever and one lever that engages the tines and transmission. The tines always turn on mine whenever it is moving forward or backwards.
    Mine has a shut off valve under the gas tank that you turn to turn off the gas. Could be that yours is frozen, but I think you can get replacements pretty easily.
    If my single belt is worn or is the slightest bit out of adjustment, it wants to slip. If the two belt drive is less sensitive to slipping then the two belt system would the one to get. I've never felt the need to use anything other than the hi-lo range lever on mine.
    Based on your questions, Dennis, I'm still not sure which tiller model you have. The briggs serial no. could be in the location shown in the attachment.
    Attached Files Attached Files
  2. #22
    Member
    Join Date
    Feb 2010
    Posts
    36
    Texas
    2009 Kubota GR2110
    Quote Originally Posted by 2manyrocks View Post
    Rocks,
    I would think it is the serial number.
    Dennis,
    I also have a shutoff valve on the bottom of my tank. It only wants to turn about a 1/4 turn. I think it's partly frozen has was mentioned above. I plan on replacing mine. Easy fix.
    Bill
  3. #23
    Elite Member
    Join Date
    Jul 2007
    Posts
    3,221
    Dennis, is your machine like CR172's but with a Briggs or do you have another model like this Pony model with a Briggs and an electric starter? YouTube - Troy-Bilt 5HP "Pony" Rear Tine, Walk Behind Self-Propelled Roto Tiller 5HP Briggs & Stratton
  4. #24
    Member
    Join Date
    Feb 2010
    Posts
    36
    Texas
    2009 Kubota GR2110
    From what I can tell. With the serial number being what it is and located where it is, this is a pre 7-5-71 horse. Sill running strong....
    But I thought the numbers for the engine indicated it was a '79 model......... So, either I misinterpreted the engine serial number, or it was replaced. Either way, now I know what parts to get if/when needed.....
  5. #25
    Platinum Member DennisArrow's Avatar
    Join Date
    Jul 2003
    Posts
    560
    Sugar Valley, Ga
    Iseki TL 2300, Kubota RTV, Kubota B7610
    Mine is definately like CR172's. In addition, it has HORSE on the shroud with all of the information about it on the big yellow sticker......I gotta take a pic.......
    Anyway....it definately has the huge slow and fast lever on the right coming up out of the right side of the transmission, actually from underneath, and then the long lever coming up from the center area of the transmission for forward and reverse............
    2manyrocks......you do know that you can adjust the belt for getting rid of slippage?????.....one adjusts the block at the base of the forward reverse lever up or down.......
    Gotta get out there and look on the engine shroud for that number.....THANKS.......Dennis
  6. #26
    Member
    Join Date
    Feb 2010
    Posts
    36
    Texas
    2009 Kubota GR2110
    Rocks or Dennis,
    Could either of you post pictures of the side shields of your tine shroud? One side of mine is missing, and I think the other has been 'modified'.... I found a new tiller shroud, but it's ~250.00........ No thanks. I can get some sheet metal and fab one myself. I'm sure one of our neighbors has welding equipment. Just really needs to be spot welded. Or I could just bolt them on.
  7. #27
    Elite Member
    Join Date
    Jul 2007
    Posts
    3,221
    The tricky part may be that the side shield doesn't come straight down and appears to flare out about 1 1/4 to 1 1/2 inches roughly. I can't figure out how to measure it exactly. The side shield is 4 9/16 from the side of the cast iron tine housing, but keep in mind that the housing is inset relative to the top of the tine shield.
    Attached Thumbnails Attached Thumbnails Troy-Bilt Horse ID-tiller-side-shield.jpg   Troy-Bilt Horse ID-tiller-side-shield-flare.jpg
  8. #28
    Member
    Join Date
    Feb 2010
    Posts
    36
    Texas
    2009 Kubota GR2110
    Thanks Yep, the one that isn't missing has been modified...... Maybe keep my eye open for a "dead horse"..... for parts....
  9. #29
    Join Date
    Jul 2003
    Posts
    560
    Sugar Valley, Ga
    Mr. 2many..........Thanks for the attachment about the serial numbers......I did find my engine numbers; but golly are they ever messed up. I need to get in touch with an archaeologist to be able to decipher them.......That's a joke but pretty true. I went to B&S web sight and tried to plug in what I could get, but no luck.........Anyway, life goes on. I really thank you guys for your input and thoughts........GOD BLESS........Dennis
  10. #30
    Elite Member
    Join Date
    Jul 2007
    Posts
    3,221
    It has been a pleasure to chat with both of you about these fine machines. I didn't understand the 2 belt 1 belt thing until Bill explained that the 2 belts go on the 2 speed transmission model. Now I get it.
    I had one of the Troy Bilt Juniors. There weren't any side shields on it, and it always did a great job for me. If someone has really dusty soil or sensitive plants, maybe the side shields become important, but I never missed them on the Junior model.
Similar Threads
  1. Troy Bilt Horse Re-power question
    By jas67 in forum Rototillers
    Last Post: 04-16-2013, 12:28 AM
  2. Old Troy Bilt Horse Parts -- good online source?
    Last Post: 03-28-2012, 08:42 PM
  3. Troy Bilt Horse reverse disc (model question)
    By tjack335 in forum Rototillers
    Last Post: 11-20-2010, 01:32 AM
  4. Troy Bilt Horse Tiller
    By dfeck in forum Rototillers
    Last Post: 08-08-2009, 06:21 AM
  5. Help On A Troy Bilt Horse Roto Tiller
    By claridon in forum Rototillers
    Last Post: 05-10-2009, 10:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
