Page 5 of 7 FirstFirst ... 234567 LastLast
Results 41 to 50 of 64
  1. #41
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,200
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Default Re: underground water lines, what size plumbing
    As for the adapters, Grainger lists a 10 pack of connectors that go from a 1" male barb to a 3/4" male NPT for $13. Those should work as long as the pressure stays below 150PSI and the temp between -80F and 200F.
    See: Adapter, 3/4 In Thread Size, PK 10 - Polyethylene Tube Fittings - Fittings - 4EMW3 : Grainger Industrial Supply
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  2. #42
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,559
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    I have done a lot of irrigation work in my yard, including using various size pipe. I'm also a mechanical engineer that works in fluid dynamics. I really encourage you to go with the biggest practical pipe size. I used 1" mains everywhere. It doesn't matter what the pipe size is upstream or downstream -- if you have a long run to make, then use as big a pipe as possible for that run. It's especially important if you are marginal on GPM or pressure, as the bigger pipe will really help preserve your capacity. Small pipes will eat it up.
    You can do some basic math to see the benefit, or consult a design table. But here's a rule of thumb -- for a given GPM and a pipe diameter D, the losses in a pipe (due to friction and things like elbows and fittings) scale like this:
    Loss ~ GPM / D^4
    Looking at that, every doubling of diameter will reduce the loss by a factor of 16, which is a HUGE effect. Or put another way, every time you cut pipe size in half, losses go up by a factor of 16. So a 1/2" pipe will have 16 times more loss than a 1" pipe. There is less difference between 3/4" and 1", but the 3/4" will still have about 3.2 times more loss than a 1" pipe.
    Losses will eventually restrict the flow enough to reduce the GPM, so that becomes a second effect.
  3. #43
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    an attempt to go over pump curves, and giving an example of difference in pipe size and friction loss.
    see attached diagram...
    again below chart and numbers are only an example and will most likely not be near your setup. but hopefully help get idea across of things.
    underground water lines, what size plumbing-pump-chart-png
    Ryan
  4. #44
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,923
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    v8only ,
    Is your water at 33 ft , and to your house considered drinking water quality?
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  5. #45
    New Member
    Join Date
    Oct 2011
    Posts
    15
    Loranger / Slidell, LA
    1991 Mahindra 450
    Quote Originally Posted by J_J View Post
    v8only ,
    My well in Loranger, LA is 30 feet deep and was tested by the state and taste fine. They will not issue an electrical permit without testing the water.
    Profnohair
  6. #46
    Member
    Join Date
    Apr 2012
    Posts
    26
    Vernon, Illinois
    Ford 8n, case 1840 skidsteer, brushcat, vermeer backhoe attchment, 72" smooth bucket, 60" toothed bucket, KK 5 foot BB
    Just wanted to share one quick thing on this topic. I had county run to my property, which involved them running a pipe to a new meter under the county road to my side of the property...then it was my responsibility (and my expense) to run whatever pipe I chose to my dwelling (a barn, in this case). The barn was 550 feet from the new meter. The water company guy strongly reccomended I use at least a 1" pipe. He also told me a tip. He said a lot of people use 1.5" schedule 40 pvc, primed and glued. For as long as that line would last (which could be indefinitely), you get ridiculous flow rate. It's easy to work with and not that expensive. But here's the big tip. He said if that ever fails, you have a ready-made conduit through which you can pull/push 1" pex or polyethylene tubing through with EASE, and renew everything easily.
    I put the 1.5" schedule 40 pvc in a trench 30" below grade four years ago, and have had no leak. I put a pressure gage on the line, so I can monitor the pressure (and potentially indicate even a minor leak). No leaks in 4 years and I have flow rate out the wazoo.
  7. #47
    Silver Member v8only's Avatar
    Join Date
    May 2012
    Posts
    214
    Mb
    1988 John Deere 755
    that is what i am told yes.
    1988 John Deere 755
    52 Loader
    JD 59 Front mount snowblower
    60" MMM
    MFWD
    48" JD Model 40 tiller
    Craftsman YS4500
    22 Hp Briggs & Stratton
  8. #48
    Join Date
    May 2008
    Posts
    1,196
    A little southeast of Syracuse, NY
    Kubota
    Quote Originally Posted by v8only View Post
    Well i am told that my well supports 20 GPM @ 33'. To fill a 5 gallon pail at my hose bib at the house it took me 120 seconds to fill so my GPM is quite low and inorder to keep my "new" lines pressurized I am told that my current pump will not be able to keep up?
    When you tested this was your well pump running? This could just be the flow rate of the system you were drawing from. Somewhere you should have a pressure tank that has a reserve of air and water it in. This air is what is pushing the water through the home, not your pump. Otherwise every time you needed water your pump would cycle on and off, and the water would be surging. The only way to know the flow rate of the pump is to either know what pump it is, or test right off the line coming into the house with the water shut off to the rest of the system. In other words to take the pressure tank out of the picture.
    Also should you decide to tie in to the line between the well and house make sure that you don't have a check valve between the house and well. Many systems I have seen do have a chack valve right before the pressure tank to keep water from flowing back down the well, even though there should be one in the well. many times these fail over time so a new one is added near the tank.
    Hope this helps.
  9. #49
    Join Date
    Mar 2010
    Posts
    648
    You can't accurately measure available well flow rate by testing at a hose bib connected to 1/2" copper.
    Wrooster
  10. #50
    Join Date
    May 2012
    Posts
    214
    Mb
    1988 John Deere 755
    ok here is some new information:
    i got my new GPM measurement from a hose bib right before it goes into my softner/pressure tank system in the basement: 30 seconds to fill a 5 gallon pail. Talking to my plumber who set up my well he is telling me my pump is a Goulds 10GS05412 four inch submersible well pump. This pump is a 10 gallon per minute HP 230 volt.
    So with this new information where do i start?
    I did some of the Design data form information that i knew anyway and here is what i got:
    Dry method:
    1/2 HP pump
    Dynamic water depth: 33 feet
    Elevation difference: 10 feet (water line from basement to new irrigation system manifold)
    Elevation head: 43 feet
    Design Pressure: 50 PSI
    Design Head: 115.5 ft. Hd
    Total Pressure head: 158.5 ft. hd.
    Initial Design flow 6.8 GPM
    Wet method:
    design pressure: 50 PSI
    Inital design flow: 10 GPM
    NOW the reason for the different in my opinion is that the elevation difference between me doing the test was 0 as i will not have to rise 10' to get the water out of the house as i got the water directly from the basement.
    Pressure loss table: (keep in mind there is alot i dont know and I did alot of estimating which will be noted below:
    water meter: 0 PSI
    backflow preventer: 3 PSI
    filter: 0 PSI
    house mainline: 1 PSI (1" mainline from well into house is approximately 10' long, then from mainline to new manifold will be about 20')
    irrigation mainline: 24 PSI (1" mainline from manifold to house bibs will be 1 line tied together for a total of 880')
    valves: 5 psi (ball valves at manifold)
    Elevation change: 4 PSI (from basement up to ground level outside is 9')
    sprinklers heads: 0 PSI
    Laterals: 6 psi (to keep maximum 20% of spinkler head value above????)
    Total PSI: 43
    SO if the above is correct my design of 50 PSI will work as my total pressure loss is 43 PSI.
    What do you all think?
    1988 John Deere 755
    52 Loader
    60" MMM
    MFWD
    Craftsman YS4500
Similar Threads
  1. Advice on electrical/water underground
    By tungularafishcamp in forum Rural Living
    Last Post: 09-14-2011, 02:21 PM
  2. Plumbing lines to new shop
    By GarthH in forum Rural Living
    Last Post: 05-13-2008, 02:40 PM
  3. Need some plumbing advice (underground)
    By Torrak in forum Projects
    Last Post: 04-12-2007, 06:36 PM
  4. underground water pipes to barn
    By mlinnane in forum Projects
    Last Post: 07-26-2006, 09:50 PM
  5. How to locate underground water leak?
    By njrqs in forum Rural Living
    Last Post: 02-16-2003, 11:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
