TooMuchGrass
Greetings All,
I just closed on a home on 2.5 acres of land. I've never had a lot this size to maintain before and was curious if folks could help me out figuring which mower/specs would be ideal for my situation:
2.5 acres - really about 2 acres if you take away the pond, house and driveway - Location South Florida
Terrain is not perfectly flat - the house, patio and surrounding area is on a elevated mound (roughly 18-24") above the rest of the yard
Yard has dips, small mounds and a few 4"-8" diameter stumps
There are trees on the property, but would say they are spaced no closer than 10' apart or so
In summer the yard somewhat "floods" during heavy rainstorms (especially in the front yard) and is pretty much unmowable for atleast a 3 days afterwards (evidence of a few mowers getting stuck in the middle of the front yard when buying the house)
Grass on this lot grows extremely fast in the summer (hopefully much slower in the winter) - in just a week it grew 2-3" - Was mowed by landscaper last week
About me:
Very limited/No experience with Lawn Tractors/Zero Turns
Can only allocate 3 hours a month to lawn work
Would like the price to be 4K or under (my better half would say 2K or under )
I was thinking for my limited time - If I could find a mower that can cut my lot in an hour - I can do that three times a month during the summer, and maybe 2 times month during winter
From this and researching a few posts - it led me to the following potential specifications:
54"+ cutting Deck (preferable 60"+)
at least 24 hp
Mowing speed 5.5+mph (lesser if larger cutting deck)
Initially I was thinking about the Craftsman 54 Inch Model 20417 Prosumer Zero Turn
Then read about delivery woes and other issues: http://www.tractorbynet.com/forums/craftsman-sears/301122-craftsman-z7400-zero-turn-3.html
Around this time the grass was really out of control and was thinking of getting tractor with a Bush Hog attachment - but not sure if this would be overkill for what I need it to do (since then have hired a landscaper to chop down the jungle)
1952 FORD 8N, BUSH HOG, FINISH MOWER
Then was thinking maybe this mower (24hp diesel w/ 72" deck) would be ideal...then read up on finish mowers and found I would have to mow every week pretty much - that and the "grass" in my area is very rough on blades - last owner said he had to sharpen the blades almost monthly - he has a similar lot size:
Riding Lawnmower Toro Groundsmaster 322D
So I am kinda back to square one - any suggestions on specs/mowers for my situation?
Thanks,
Bob
Images below of lot in question:
About me:
at least 24 hp
Thanks,
Bob
