HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Related Equipment > Lawn & Garden
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-26-2009, 08:23 AM   #1 (permalink)
Gold Member
Jay4200's Avatar
Default 16HP B&S Carb Dissasembly?
I took my new-to-me Snapper for a spin around the neighborhood yesterday. It ran pretty good, but felt a little lean on top. I want to pull and clean the jets, but I'm not sure how to get there. Closest I got to the carb innards was taking apart the fuel pump, and I did load some carb cleaner into the thing via the fuel line. I generally like to do a full tear-down and cleaning, but got thwarted by complex assy, and couldn't find anything that looked like a carb bowl. Can anyone help with a how-to and/or pics of how to get inside the carb and where the jets are located?
This is the tractor:
This is the motor:
Lastly, any hints or links on and how to tune the throttle and/or governor? The throttle set-up is set a little tight, but basically correct as per manual, yet the motor doesn't move off idle until the throttle lever is at about 2/3, and doesn't seem to rev up as high as it should at WFO. I haven't checked RPMs with a meter, but it definitely has a mid-throttle sound/feel when fully cranked.
Thanks all - JayC
Jay4200 is offline   Reply With Quote
Old 10-26-2009, 03:07 PM   #2 (permalink)
dfkrug's Avatar
Default Re: 16HP B&S Carb Dissasembly?
Yours is nice and clean and much newer than mine. Here is my 1979
vintage B&S 16 hp twin. It sat for years in a field, but once I took off
the carb and cleaned it up, it starts right up. My sheet metal is
removed for this photo, but you can see the carb and manifold. The
tractor it was attached to was a Craftsman. Mine is a vertical shaft
and yours seems to be horizontal. My carb has a nice brass float and
easy-access jets.
__________________
See my TBN projects at:
http://mysite.verizon.net/resyfcgt/
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Diesel fuel dispenser
Bucket dentistry
custom hydraulic b/h thumb
adapting a 4-in-1 bkt to my Kioti
JD 4300 rebuild (new!)
dfkrug is offline   Reply With Quote
Old 10-30-2009, 09:38 PM   #3 (permalink)
It looks as if you may have to pull the front end hood section off to get to the carb completely. I have an older JC Penney model and I had to do that to get to it easy. It has the 18 hp engine. It has no main jet adjustment on it. ie. the main jet is fixed and not adjustable, which sucks. It does have an air mixture screw and a idle screw. zman
zman007007 is offline   Reply With Quote
Old 10-30-2009, 09:45 PM   #4 (permalink)
carpenter383's Avatar
Not sure about your specific carb, but yo might just want to try cleaning everything good before you start making any adjustments.
You should be able to pull the governor spring tighter to raise the rpms. Just find where the spring goes from the throttle linkage to governor control arm and pull the spring further through the hole, then bend the end so it can't slip back. Do this a little at a time or it'll rev to the moon!
__________________
DK40SE, loaded R4's, KL401 loader with toothbar = a good chunk outta the bank each month
Problems cannot be solved at the same level of awareness that created them.
carpenter383 is offline   Reply With Quote
Old 10-30-2009, 09:49 PM   #5 (permalink)
Also if no one has tinkered with the governor I would leave it alone. You can really screw things up here, or blow a engine if you dont know what you are doing. I have no idea of you expertise, so just a suggestion. One way you can find out if it is getting full throttle is remove the air cleaner, then push your throttle control wide open with engine off, note position, then loosen the clamp that holds the outer housing of the throttle clamp and see if it will move any more to open the throttle wider. If so, push it as far as it will go, then tighten the clamp back down there. Crank engiine in idle position, and check out your throttle response then. zman
Old 10-30-2009, 10:16 PM   #6 (permalink)
Quote:
Excellent advice! If, after doing all the normal cleanings and adjustments, and checking the RPMs with a tach, the engine is turning below the spec, then mess with the governor. Most lawn mower motors spin about 3000 rpm and snowblowers spin at 3500-3600.
jhwentworth is offline   Reply With Quote
Old 10-30-2009, 10:53 PM   #7 (permalink)
Carpenter, your RPM"S may rev to the moon, but your soon to be blown engine will still be here on earth. Thanks for the kind words Mr. Wentworth. zman
Old 10-30-2009, 11:18 PM   #8 (permalink)
Well that's what I was getting at
He specifically asked if there was a way to adjust the governor for more rpms
__________________
Old 11-04-2009, 03:09 AM   #9 (permalink)
Member
sawz all's Avatar
I just rebuilt my 16 hp briggs on my bolens. Same engine as yours. Very easy job and if you still want to know about it just let us know you're still interested and I'll tell you about it.
Kevin
sawz all is offline   Reply With Quote
Old 11-07-2009, 11:18 PM   #10 (permalink)
Gold Member
Check with your local dealer, the Briggs Engine Manuals were the cheapest that I have ever found. The manual will have governor settings. Might even find one online, try google.
IIRC the high speed jet is accessable without removing the carb or disassembling. There should be a hex head plug on the side of the carb toward the botom, a 1/2 or 9/16". I think the jet is inside the hole the plug is covering.
The carb top gasket must be in good condition as there are passages through it. Also it should have the fuel pump on the carb operated by crankcase pressure/vaccum.
Stimw is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
Page generated in 0.35850 seconds with 9 queries
