ZD28 maintenance hatch
   / ZD28 maintenance hatch #1
tawilson
Theresa, NY
NH2120 RTV500 Bobcat S250 Kubota U25s
Finally warmed up enough to start working on making some sort of maintenance hatch for the ZD28. I have never had the platform off it before. Unbolting it was simple, 6 easy to get at bolts. The problem then was it couldn't get over the brake pedal. I unbolted the pedal, got the platform off and cut a slot in it behind the pedal so I don't have to remove it to remove the platform. As easy as it is to get off now, I might not go any further. After seeing the mess of dirt and grass that collected underneath it, I want to remove it and clean it out anyways. I'd like to take the plate off under the seat before doing anymore. 4 easy to remove bolts. Problem is I don't know how to take the knob of the deck height adjustment. Does it unscrew or just pull off? I tugged on it pretty good and it didn't budge.
I see on the new ZD's the plate and platform are one piece and hinged under the seat. I don't think I can do that because of the brake pedal.
   / ZD28 maintenance hatch #2
I made the same cut for ZD21.
Makes getting to the deck below a snap.
Why didn't Kubota think of that?
I can't believe it took me a year and a half to think of it. After looking it over, I guess taking the plate off under the seat won't gain me much more access than just flipping the seat up will do. I think I'm going to put the 2 bolts back in under the platform that bolt the fenders to the frame, and drill and tap the frame so I can just put a couple of bolts in from above. The ones underneath are a little harder to get at.
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
JARRAFF TREE TRIMMER (A52706)
JARRAFF TREE...
2014 CATERPILLAR 336EL EXCAVATOR (A52705)
2014 CATERPILLAR...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
