Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Sep 2011
    Posts
    2
    Default Considering an R4041
    Has anyone had experience with the LS mode R4041. I've not been able to see one personally but the tires/wheels seem undersized for a 40 hp tractor. Are these tractors more compact than a JD or kubota? Also, the dealer is a couple hours away. How would that factor into your decision?
  2. #2
    New Member
    Join Date
    Jun 2011
    Posts
    9
    Edmonton Alberta
    Toro 328D, Cat 272D
    Default Re: Considering an R4041
    We purchased a R4041H In July, and have since put on about 60 hrs. Our dealer is about 1.5 hrs from where I live, and about 3 hrs from where we use and store the tractor. (They are the only dealer in Alberta).
    We have 10-16.5 & 43x16-20 R4 tires on the unit, I'm not sure if that's an optional or standard size for the R4 tire option.
    As for the tractor size, its similar to the L series kubota and Deere 4105, although the LS is quite a bit heavier, plus the loader is more than up to task (there is a 15 cubic ft bucket on it currently)
  3. #3
    Join Date
    Jan 2005
    Posts
    153
    Austin, TX
    Many LS tractors...current Fave is XR4150HC
    Quote Originally Posted by mlucius View Post
    Hi, Lucias. Welcome.
    I'm a dealer for LS, and agree with you that the stock wheels and tires on the R4041 are little bit undersized, so we spec all of ours with the larger size that comes standard on the R4047. You local dealer could probably do the same.... it adds a few hundred dollars to the price, but most of our customers seem to like it better that way.
    Here's a link to what the R4041 looks like with the bigger wheels/tires...
    RCO - LS Tractor R4041 from RCO TRACTOR, a UTDA Dealer
    And here's a picture of what last year's version of the same tractor (the R4010) looked like with the standard tires.
    Attached Thumbnails Attached Thumbnails Considering an R4041-ls_tractor_r4010_005-jpg
    John Ryan
    RCO Tractor
    512-535-6862
    john "at" rcotractor.com
Similar Threads
  1. R4041 Pics
    By boomer632 in forum LS Tractor Owning/Operating
    Last Post: 03-26-2011, 08:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
