ProdaddyTX
- Joined
- Jan 11, 2005
- Messages
- 156
- Location
- Austin, TX
- Tractor
- Several LS tractors...current Fave is an MT225s
We've had this discussion with our LS service rep, and were told that it's not that uncommon to see 3pt attached backhoes break the rear case if they get used really hard, and that sort of breakage would not be covered under warranty.... which to me seems totally reasonable. They won't do some blanket cancellation of warranty based on attaching somebody else's implement, but if you have a tractor failure caused by that implement then it's another story.
In our experience LS has been very reasonable and given customers all the benefit of the doubt in warranty situations.
I'm curious what other backhoes you might be considering? The LS backhoes are really stout, and a LOT cheaper and nicer than the Koykers we've sold in the past. LS's quick attach subframe setup is really nice too.... on most models you don't even have to remove the 3pt arms to attach the backhoe, just raise 'em up and hook up the backhoe...no tools required.
