Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,703
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: New Attachment
    Quote Originally Posted by mangus580 View Post
    why not rotate the bracket 90 degrees, eliminating the stress on the hoses as well?
    OR 45 degrees would maybe work better. As you say photos are deceiving so if it works as is then it is good. Just be carefull with those ties to keep everything out of the way. I had put some tyraps, and rope on some hoses on my FEL to keep them away from the tire when turning. Well one day the ties loosened up or broke and while backing up and turning sharp the front tire grabbed two of the hoses and ripped them from the quick connect. Luckily all it broke was two male couplings. Now I have rerouted all of them to be out of the way without ties holding them.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  2. #22
    Gold Member
    Join Date
    Jun 2004
    Posts
    275
    Niagara County, N.Y.
    Long 530, 2360, 360,2310, Ford 641, 8N, 2N
    If your tractor is still under warranty, I would advise to check warranty policies on the tractor- loader with LS. In the event of a failure, as a result of use of that bucket. Just an idea.
  3. #23
    Platinum Member rwork's Avatar
    Join Date
    Apr 2012
    Posts
    605
    Mississippi Gulf Coast
    Kubota B6100 LS R3039H
    Quote Originally Posted by trac View Post
    Why would I worry about the warranty using a stump bucket?? No difference in that and a root grapple. You can do just as much damage with the standard bucket, if not used properly. I'm not afraid to work my machine, I just try and use common sense!!
  4. #24
    Silver Member RAYJAY's Avatar
    Join Date
    Nov 2012
    Posts
    151
    CLIFFORD PA
    LS 3039H
    why would you have a failure with that bucket?? my dealer sold me a 4 in 1 bucket for mine.
    can't wait to see how it works was looking at them also ......
    (there is way to many toys to buy for this tractor ...lol)
    Jeff
  5. #25
    Join Date
    Apr 2012
    Posts
    605
    Stump bucket was delivered today, and looks good and stout. Can't wait to get it in the dirt! It should perform well. I would think you would be more likely to do damage with the standard bucket, as you would with this one. All of the digging force is concentrated right in the center of the loader, as it should be. Unlike using the wide bucket and having the pressure exerted on a corner. That's how loaders get racked. I'll be willing to bet I'll get the back end off the ground, though !!!
  6. #26
    Platinum Member joemd11's Avatar
    Join Date
    Jan 2010
    Posts
    990
    Western Pa
    LS R3039, Power King 1614, Simplicity Soveriegn 75th Aniv model.
    Some pics of the new stump bucket in action would be good!
  7. #27
    Join Date
    Apr 2012
    Posts
    605
    Well, as luck would have it, the weather was nasty this morning. I did go unload my new stump bucket, and could not resist the urge to just dig something up. I was so wet everywhere it was ridiculous. I dig manage to dig up a few small trees, and a few small stumps. I think its going to work out fine. Can't wait to really try it out when it dries up a bit.
    Here are a couple quick pics. The small saplings only take one stab, and pop right out!
    Attached Thumbnails Attached Thumbnails New Attachment-2013-01-16-09-58-a   New Attachment-2013-01-16-10-38-a
  8. #28
    Gold Member mangus580's Avatar
    Join Date
    Sep 2010
    Posts
    490
    Western, NY
    Bolens (Iseki) H1502; LS R3039
    What diameter is the 'sapling' in the first picture? Looks like its between 4 and 6 inches?
  9. #29
    Join Date
    Apr 2012
    Posts
    605
    Yep, that's about what it was. One scoop took care of that one!
  10. #30
    Join Date
    Sep 2010
    Posts
    490
    Western, NY
    Quote Originally Posted by rwork View Post
    That says it all right there - I NEED one!!!
    Guess I better get the tractor first though....
Similar Threads
  1. Buying Advice what attachment do I need?
    By albert in forum Toolcat
    Last Post: 06-15-2011, 03:38 PM
  2. What attachment do I need?
    By TheGoose in forum Attachments
    Last Post: 03-19-2010, 10:30 PM
  3. Did you see this attachment?
    By Tompet in forum Attachments
    Last Post: 03-19-2010, 11:08 AM
  4. Skidsteer attachment vs loader attachment
    By DUSTMAKER in forum Construction Equipment
    Last Post: 06-07-2008, 06:08 PM
  5. What attachment do I need?
    By grafpatrick in forum Attachments
    Last Post: 03-23-2005, 07:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
