Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 56
  1. #21
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,897
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: My R3039 Mods
    Quote Originally Posted by mangus580 View Post
    For the hooks, and the front 2 bolts on the hitch, I used 1/2" x 3" Grade 8. The rear 2 bolts on the hitch, I used 2 of the bolts that came with Kens hooks.
    Be warned when you drill... that the weld is centered front to back in the bottom of the tube. I learned the hard way!
    My original plan, was to drill/tap the top hole, thread the bolt into it from the bottom up, creating a stud for the hook plate, then drop plate on, and put nut over it. I opted against it, because the nuts were too tall, and would have interfered with the chain and hook.
    I know Ken urges against clamping the tube like this, but the LS tubes look pretty thick, and I couldnt see any other way of doing it that I would have been happy with.
    Like my buddy says... if the hooks start to get loose, you know you lifted something too heavy!! LOL
    If you are worrying about crushing the tubing, why not put a piece of wide flatbar 4" (wide enough to span the width of the hooks mounting bolts)x 1/4" thick the width of the FEL tubing underneath like a giant double washer that catches both bolts . If it extends to both edges, it would quadruple the strength of the bolted joint. For the receiver hitch maybe use 2 separate bars for each side.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  2. #22
    Gold Member mangus580's Avatar
    Join Date
    Sep 2010
    Posts
    490
    Western, NY
    Bolens (Iseki) H1502; LS R3039
    The major issue with making your own tube, is most square tubing has the weld to contend with. When making receiver hitches, you have to remove the weld for the hitch to slide into it.
    In regards to the strength of the bucket tube, I am not that concerned, I do not think its going to be an issue honestly. I really think that if it were going to 'crush in' the bottom.... It would 'pull out' the top if it were just welded on. (if that makes sense!)
    Quote Originally Posted by Gary Fowler View Post
    I looked at all the receiver tubes and HF does have just a plain 12" long tube with nothing on it other than the little reinforcement ring at the end but at $13 sounds like a fellow could do better just buying the stock tubing and making them himself if in the market to sell them. I don't have a clue as to how much 2x2x1/4 tubing cost per foot though, and then you have to cut to length, cut the 2.5 tubing for the reinforcement at the end, drill the hole for the pin. Maybe $13 isn't too bad after all.
    It looks like the 3500# would fit nicely on a FEL and plenty strong for a CUT.
  3. #23
    Gold Member LittleBlueTractor's Avatar
    Join Date
    Dec 2009
    Posts
    435
    Houston
    LS S3010
    The HF 12" receiver tube is the one in this pic:
    Attachment 228918
    Also got the hook you see in it (and the pin as well) from HF. Plus you can find their 20% off coupons almost everywhere you look. This one is good till the end of the month:
    My R3039 Mods-20off912-aff17549-jpg
    Lil' Blue
    LS Tractor S3010 w/FEL
    Ag-Meier Mohawk Brave 5' cutter
    Armstrong Ag BB05-Std 5' Box Blade
    TSC CountyLine Middle Buster
    WildKat 48" Single Cyl Grapple
    Versatech 42" Pallet Forks
    A "no name" Stump Bucket that works really well
  4. #24
    Join Date
    Sep 2010
    Posts
    490
    Western, NY
    Finished up the wiring for the light.
    Here is a shot of the solenoid and fuse I used at the battery. This is triggered from the key, and feeds a 6 fuse fusebox I put under the dash ziptie mounted to the factory fusebox. (forgot to get a pic of that...)
    My R3039 Mods-2013-02-13-12-52-a
    And here is the switch mounted in the dash.
    My R3039 Mods-2013-02-13-13-00-a
  5. #25
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,951
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Here is the receiver I bought...
    3500 Lb. Step Bumper Receiver
    They also have this one, which has a wider mounting plate (may be better for bigger tractors)
    5000 Lb. Step Bumper Receiver
    I also plan to pick one of these up on my next visit to keep in it I think...
    D-Ring Receiver Hitch
    Kenny, the trick to finding them is to type 'receiver' into the search...
    There is no way I can compete with that. I talked with my metal supplier today- they have seamless tubing made for this use, but by the time you buy it, cut it, drill it, weld it to a plate, then paint it I couldn't even do it for twice that amount. I also talked with the supplier of the hooks I use and they don't carry anything like it either.
    Sorry guys, Horrible Fright it is if you want a bolt on receiver hitch.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  6. #26
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    I am working on wiring and plumbing for a grapple and I used a spare fuse in the fuse block. I followed the wire from the rear of the fuse block in the wiring harness and it ended in a plug-in to the next assemble the wire just didn't exist in the next assemble only a blank opening. The plug end with the wire in it was a female and the other side was blank, so a crimped a staycon to the end of a wire and pushed it into the blank side it snapped in so I plugged the two ends to gether and walla instant wiring.
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  7. #27
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Quote Originally Posted by kennyd View Post
    Sorry guys, Horible Fright it is if you want a bolt on reciever hitch.
    Horible Fright............now that's funny I don't care who you are!
    Montana R4944
  8. #28
    Join Date
    Sep 2010
    Posts
    490
    Western, NY
    I looked for one to do this with on mine, but could not locate one. What I did find, is the fuse marked 'Spare' is fully connected, and seems to control brake lights....
  9. #29
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    No the one marked spare in mine worked out just right. I love it when a plan comes together, because they so seldomly do!
    Montana R4944
  10. #30
    Silver Member BlackDogTx's Avatar
    Join Date
    Jul 2012
    Posts
    131
    Waller, Texas
    LS G3038H, Kawasaki Mule 3010 Trans Diesel
    Quote Originally Posted by Guesseral View Post
    Agreed.. My last experience with them would qualify.. Their customer Service is horrible..
Similar Threads
  1. price on R3039
    By leonardo in forum LS Tractor Owning/Operating
    Last Post: 11-03-2012, 12:17 AM
  2. LS R3039 2 days away
    By pigs in forum LS Tractor Owning/Operating
    Last Post: 05-09-2012, 07:40 AM
  3. Looking at a R3039
    By Alan Davis in forum LS Tractor Owning/Operating
    Last Post: 09-21-2011, 12:02 PM
  4. My New LS R3039 On It's Way
    By Jimjammer4 in forum LS Tractor Owning/Operating
    Last Post: 04-06-2011, 10:09 PM
  5. R3039 is in!!!
    By joemd11 in forum LS Tractor Owning/Operating
    Last Post: 04-04-2011, 08:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
