My R3039 Mods
   / My R3039 Mods #1
mangus580
Gold Member
Western, NY
Bolens (Iseki) H1502; LS R3039
I am starting this thread as a place to list off anything I do to my 3039....
Today, I added 2 of Ken's bolt on hooks, and a receiver tube. Also finished running the wires for my 'idiot light'. Just need the switch for that now, and I decided that I am going to add a second 'fuse box' for that light, and any other work lights I may add in the future. I am thinking of putting a heavy solenoid/relay in line on the wire from the battery sot hat fuse box will be switched via the key. I will need to figure out where I can tap into the wiring for that purpose.
Also, I discovered a pair of wire sets under the hood that are 3 wires in each set, and the sets match. They are I believe green, yellow, and black. Turns out they are low beam, and hazard flashers, (with the black being ground). I guess some tractors must have lights near the hood/loader uprights from the factory. Figured I would mention it, in case someone needs them! I may use them for a set of lights up near the loader someplace...
Sorry about the crappy pictures... forgot to get them when it was inside at my buddys shop.
   / My R3039 Mods
Just to put it all in one place.... here is what I posted about the Idiot Light last week....
Since my driveway is short, and has a bunch of road frontage (not to mention a 55mph road), I felt it best to mount a Idiot Light on my tractor. Can be thought as me being an idiot in the road, or me trying to avoid idiots on the road, your choice!
I wanted it to be semi protected when the ROPS was up, so it hangs underneath. I extended the mounting forward, to make side visibility better. I have the wires set up appropriately to allow the ROPS to fold down still too, as i need it dropped to fit in the shed.
I have yet to wire it up fully, need to decide on a switch, and find warmer dryer weather to lay underneath to run the wires. (wired to my booster pack to show it working)
What I need to know from the LS guys.... does anyone have a schematic? Where is the best spot for me to connect into for this light? Can I take advantage of one of the 'spare' fuse holders? Anyone with an R series have a preference as to where a switch might get mounted? (they really didnt give us many options)
Also noticed 2 different unused connectors behind the seat!! And several under the dash. Hence the desire for a schematic!!
2013-02-02 16.33.26.jpg2013-02-02 16.33.17.jpg2013-02-02 16.33.10.jpg2013-02-02 16.33.02.jpg2013-02-02 16.32.55.jpg2013-02-02 16.29.29.jpg2013-02-02 16.29.15.jpg2013-02-02 16.28.59.jpg
And here is the switch I am going to use, and place it just to the left of the key...
   / My R3039 Mods #3
Well if you are going to put all of the changes you make on your tractor this could be will be a long running thread expecially when you make a change 20 years from not!:D
   / My R3039 Mods #4
   / My R3039 Mods #5
View attachment 302615View attachment 302615View attachment 302616
I think all the cab models have turn signals so those wires you found would be for that I suppose. Looks like LS factory uses the same wiring harness for all models so the wires are there for cabs or not even if the tractor is not available with a cab at the present time.
   / My R3039 Mods
How did you bolt the hooks and tube on with the double walled bucket that the LS's have? What was the length and diameter of the bolts? I wanted to go with the Kens hooks and trailer receiver too..
For the hooks, and the front 2 bolts on the hitch, I used 1/2" x 3" Grade 8. The rear 2 bolts on the hitch, I used 2 of the bolts that came with Kens hooks.
Be warned when you drill... that the weld is centered front to back in the bottom of the tube. I learned the hard way!
My original plan, was to drill/tap the top hole, thread the bolt into it from the bottom up, creating a stud for the hook plate, then drop plate on, and put nut over it. I opted against it, because the nuts were too tall, and would have interfered with the chain and hook.
I know Ken urges against clamping the tube like this, but the LS tubes look pretty thick, and I couldnt see any other way of doing it that I would have been happy with.
Like my buddy says... if the hooks start to get loose, you know you lifted something too heavy!! LOL
   / My R3039 Mods #7
Hi,
I apologize for my ignorance in advance, but when you say "clamping the tube", can you give a bit more detail on what you mean by that? I want to add some of the Ken's hooks to my G3038.
Thanks,
..E
   / My R3039 Mods
Just basically drilling a hole through both layers of the tube and bolting the hook on. See if these pics help.
   / My R3039 Mods #9
View attachment 302912View attachment 302913
OK.. Gotya.. So about the weld in the tube, did you just drill through it or what did you mean about that also? I am ordering my hooks this afternoon, just want to be ready to install 'em..
Thanks again!
.E
   / My R3039 Mods
I did essentially drill through the weld, just wanted to mention it was there, as you need to take a little more care in your drilling as to not break your bits.
What I had done, was drilled roughly 1/8" pilot holes. They ended up being off center front/back a little because they walked to the front of the weld. But with those holes in place, when I drilled with the 1/2 bit, it just cut the weld out of its way. Take your time drilling, and dont forget to use coolant or oil on your bit.
Honestly, I would have bought weld on hooks, if I didnt want to fight with fixing the paint after welding them on my brand new bucket :D
