Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 47
  1. #21
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Default Re: R4041 Loader Issue LB4101
    I watched your video and mine is the same. I agree with Brian, but I also think a lot of that can be adjusted out Not sure for sure but I am going to try on mine, I just don't like the cold any longer! I think if the linkage (under the boot at the joystick) and the cable are lubed up and the operation is smoother the dual operation will be better. I am not positive and I have been wrong before well ok I was right once!
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  2. #22
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,240
    SouthEast Michigan
    Massey 1652 HST Cab
    Default
    Quote Originally Posted by MtnViewRanch View Post
    This is 100% combination operator and loader joystick. These joysticks are not really intended to be used as a multifunction (same time) setup IMO. Your video shows this as in sometimes it works and others not. That is the operater, but not that it is the operater's fault really. The valves just are not intended to be used simutainiusly is all.
    One of the reasons that I think that it's funny when people want a true 3rd function on these tractors vs just a diverter. They think that they want to work 3 functions at the same time when in reality it is about all you can do to get 2 to work together.
    On the positive side, there isn't anything wrong with the tractors.
    While I'm not perfect, and I'm not adverse to placing blame on myself if/when warranted.... I'm pretty good with a loader. The very fact that other tractor brands don't have this issue (that I've experienced anyhow) shows that either something is wrong, OR that the design of the system, or joystick, is flawed. It should not be that difficult to find the spot.
    I'm still wondering if it's only some, or all, of us experiencing this.
    In the grand scheme of things, it's not a big deal... Until you're trying to be really precise with forks.
    Sent from my Motorola Photon using TractorByNet for Android
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  3. #23
    Member
    Join Date
    Feb 2013
    Posts
    26
    Forest City Pa.
    LS,Kioti,Branson Dealer
    Quote Originally Posted by TSO View Post
    OK. I'm not experiencing the "limp bucket" problem LOL... But I'm wondering how many other owners notice the issues with dual-action loader movements? Hansen, if u get a chance, can you play with the ones on your lot and see if they do it?
    Like I said, I can lift the arms AND curl at the same time, and I can lower the arms AND drop the bucket simultaneously... Although it's sometimes difficult to find just the right spot.
    I can't recall if I've ever been able to lift the arms AND drop the bucket simultaneously (or drop & curl)...
    And like I said, my Kioti didn't have the issue, neither does my buddy's (2) kubota's. That's why I feel it's either a problem with my tractor, or a problem with the design.
    Maybe it's just the joystick itself? Is there a way for me to check if the pressure is up to spec, or does the dealer need to? I'm not really concerned with increasing the pressure to gain more strength, I'm happy with that as it is. Just trying to troubleshoot. Hey, maybe the limp bucket is caused by an un-full oil reservoir, or maybe the reservoir is too small for this loader?
    I just checked a couple of machines in the yard. I can do two functions at once but I do notice a spot that the lever feels as it lets one spool to be favored over the other one. I beleive it is the way the handle is supported with the fixed ball and the two cables also support the cable with spring tension. But it is not very noticeable or as bad as your machine. I would make sure your handle is centered by pushing the lever lock in. The lock should go in with out moving the handle. If not the handle is not adjusted correctly. Also make sure the fixed ball is tight in the block. Do you have any play in the cables? To check the pressure you need a gauge with a min pressure of 3000 lbs and a matched coupler to plug into the loader lift hose. Hope that helps
  4. #24
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,414
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    I believe that the mechanism is the main culprit. I know that with both of my Mahindras that KMW the manufacturer of most of Mahindra's loaders says that the valves are not multifunctional. On my 7520 it operates pretty much as your video and yet with my 3215 it works fairly well. Yet niether are even close to the quality of our 580 Case TLB.
    It is what it is, and unless someone wants to spend some $$$$, I doubt that it is going to get much better. We usually get what we pay for.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  5. #25
    Silver Member boomer632's Avatar
    Join Date
    Jan 2011
    Posts
    205
    Steeler Country
    2011 LS R4041EZ - 2014 Bad Boy CZT Elite - 1948 Ford 8N
    Default
    Well back to the bucket sway at full dump..I went out today and tried to duplicate the issue and could not. It worked as it should with no sway. Could this be because the hyd oil was cold? When I noticed the issue the other day I had been using the tractor for over an hour and the hyd oil was up to operating temp. Any thoughts? I also tried several dual function operations that are being discussed here too. I was able to do several but as expected.. the movement of bucket and arms was considerably slower. I think its normal when using two circuits at same time that both will get reduced flow as opposed to using normal single circuit operation.
    2011 LS R4041EZ - 1948 Ford 8N - 2014 Bad Boy CZT Elite
  6. #26
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,903
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by Gary Fowler View Post
    My P 7010 does this also and is quite a delay when engine is idling, so I don't think there is a problem with linkage just oil flow as Hansen Equipment explained.
    Re-thinking this, I don't think mine did this when new either. Have to remember to check for slack when I roll it down and see if it is in the pins or cylinder. It could be a loose nut inside the cylinders causing it or the pins may be worn, but mine only has 79 hours on it and it has always been well greased, so it should not be worn.
    If the cylinder moves back and forth then it has some slack internally and could be the nut has backed off that holds the piston on the rod.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  7. #27
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    Gary , would it have that slack with 1 cylinder piston nut backed off ? I would have thought the other cylinder would have kept it from moving so much.I think mine is as Hansen Equip descibed, because mine seems to do it more with the heavy grapple on than with an empty bucket, but it does do it with both.
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  8. #28
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,010
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    Hi everyone. I too experience exactly the same things. Thanks, now I understand how it happens.
    Blessed Be.
  9. #29
    Join Date
    Jun 2008
    Posts
    10,903
    Bismarck Arkansas
    I just checked mine and I think the problem is in the linkage for the self-leveling action. I can let my bucket hang down and move it back and forth. There is about 1/8" of slack in the hole and appears that it was cut too big for the pin. I will go out an take a photo of the area for you guys to check yours.
    You can see the slight gap at the top in the grease mark and it is about like that all the way around which while not being a lot of difference, it allows the bucket to move a minimum of 2-3" back and forth by hand at the cutting blade level
    Attached Thumbnails Attached Thumbnails R4041 Loader Issue LB4101-img_1203-jpg   R4041 Loader Issue LB4101-img_1204-jpg   R4041 Loader Issue LB4101-img_1205-jpg   R4041 Loader Issue LB4101-img_1206-jpg
  10. #30
    Join Date
    Jun 2008
    Posts
    10,903
    Bismarck Arkansas
    Any one else have slack around this bracket. While it isn't a lot of slack, it does allow quite a bit of movement in the bucket
Similar Threads
  1. New R4041 !!
    By TSO in forum LS Tractor Owning/Operating
    Last Post: 03-05-2013, 07:43 PM
  2. Any CAB options for R4041 ?
    Last Post: 03-01-2013, 02:08 PM
  3. LS Tractor R4041
    By heitjer in forum Owning/Operating
    Last Post: 06-16-2012, 12:21 AM
  4. Considering an R4041
    By mlucius in forum LS Tractor Owning/Operating
    Last Post: 09-21-2011, 11:27 AM
  5. R4041 Pics
    By boomer632 in forum LS Tractor Owning/Operating
    Last Post: 03-26-2011, 07:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
