Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
  1. #31
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    Default
    Be home tomorrow and I'll check mine
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  2. #32
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,903
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: R4041 Loader Issue LB4101
    Drop the front of the blade till bucket is in vertical position and see if you can move the bucket back and forth any. Mine doesn't have any slack in the cylinders, it is all in those pin and bracket connections.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  3. #33
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    Quote Originally Posted by Gary Fowler View Post
    I checked mine tonight and all the slop is in the pins,the cylinders dont move, but theres slop on both ends and the pins in the linkage and bucket.Does anyone know if the pin locknuts can be tightened to take out some slop ?
    I'll take most of the blame, I dont grease it as often as I should.
  4. #34
    Join Date
    Jun 2008
    Posts
    10,903
    Bismarck Arkansas
    Quote Originally Posted by Bladehauler View Post
    That's the way mine is and I grease the heck out of it. Maybe it is cheap pins or the grease is not staying in the pin area. I know everytime I grease mine, I am wiping grease off the hood for a few hours as it squirts out of the pin area. My tractor has less than 80 hours on it so pin wear should be minimal and the self leveling brackets seem to have a lot of slop also.
  5. #35
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,240
    SouthEast Michigan
    Massey 1652 HST Cab
    I have not looked at the pins yet (to check for slop) ... but I was moving snow the other day with mine, and noticed that when I went to "full-dump" and tried to "shake" out the leftovers in the bucket, mine would go limp for a short time also. Sounds like this is another design flaw with these loaders. I know, I know... it's designed to be like that, it isn't meant to be smooth, it's only supposed to do THIS or THAT... again, it seems like an LS problem, because the other tractor brands (new CUT's) don't have these issues with the loader.
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  6. #36
    Join Date
    Jun 2008
    Posts
    10,903
    Bismarck Arkansas
    Anyone have a LS dealer close by that they could discuss this obvious problem with. Mine is 70 miles away. It sounds like and issue with all loaders on all of these tractors.
  7. #37
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Mine hasn't done this at all. I'm only at 55hrs, but I've spent most of that using the loader.
  8. #38
    Platinum Member rwork's Avatar
    Join Date
    Apr 2012
    Posts
    605
    Mississippi Gulf Coast
    Kubota B6100 LS R3039H
    Default
    I really haven't noticed this on mine, either. I'll check it out this weekend, though.
    2012 LS R3039H, 6' Howse HD Box Blade, 4' Root Grapple, CID Stump Bucket
    1975 Kubota B6100, Craftsman Garden Tractor, eXMark Lazer Z mower.
  9. #39
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,010
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    My loader gripes probably became legendary here when I found I couldn't roll the bucket back with the strength I was used to with my old CubCadet. That, and it wouldn't even reach my deck with a keg of beer in the bucket, as I had grown accustomed to doing with my little old Cub. LS and my LS dealer upgraded me to the 2011 and up larger bucket cylinders, though improved, it still wasn't the power I was used to. I just bought an aftermarket quick attach for the used Cub I just got. I got it on there and thought that with the sun shining here for a change, I'll get some pictures of the two tractors with their loaders set up for comparison. The LS 4100 loader is set well forward, as well as higher from the ground. It is just plain smaller.
    R4041 Loader Issue LB4101-cub-air-filters-010-jpg
    R4041 Loader Issue LB4101-cub-air-filters-008-jpg
    It is a bit hard in the photo to see the why the roll-back strength is different, but it is mostly in the spacing of the pins on the quick attach (I should have gotten a closeup). As for height and reach, it is easy to see the difference in the length of the booms. The Cub is reaching 13 inches higher than the LS, and the LS is on higher ground than the Cub.
    Of the two tractors, the LS kicks serious butt for comfort and PTO power. But now I have a loader that will do more. The weakness of having the Cub's bigger loader is in the Cub itself. So, with the Cub 7***s, Case IH 1140s, and Mahindra 28, 30, & 3215s (all the same Mitsubishi built machines), the front axle is not strong enough to carry the loads its loader can lift. I repeatedly blew the front wheel bearings out of my old one. I will be very careful about how much I weight I try lifting with it now.
    BTW, the cub never has that issue of the bucket having that gap in power that this thread started with.
    Attached Thumbnails Attached Thumbnails R4041 Loader Issue LB4101-cub-air-filters-010-jpg   R4041 Loader Issue LB4101-cub-air-filters-008-jpg
    Blessed Be.
  10. #40
    Gold Member MrChris's Avatar
    Join Date
    Dec 2006
    Posts
    341
    Georgia
    Mahindra 3215HST
    Default
    That's interesting. Just some clarification. The Mahindra 2615, 2816 are the same as the Cub 723* series tractors. Is the Cub loader made by KMW out of Kansas? Looks like the Cub 727* series matches the Mahindra 3015. The 3015 has a larger turbo engine and a different loader. It's rated to lift more but has a slightly lower reach. The Mahindra 2815/3215 and 3316 have some differences, somewhat upgrades if you like since they are newer designs. More spacious operator platform, fuel tank under hood, different front and rear axles, different HST trans and loader is again different with even higher lift capacity and even slightly lower reach than the 3015. I know the loader buckets on the 2615/2816 though the same width as the 2815/3015/3215 have less depth and thus less volume capacity, maybe in an effort to reduce the weight on the front axle, that's why I was curious as to who manufactured the Cub loader.
    '06 Mahindra 3215HST,KMW ML111 FEL,BushHog SBX65 Boxblade,BushHog RZ160 Rotary Cutter,Kasco KOS604 Seeder,Cosmo 250 3PT Spreader,Southern 6' Landscape Rake,Rhino LR 6' Rear Blade
Similar Threads
  1. New R4041 !!
    By TSO in forum LS Tractor Owning/Operating
    Last Post: 03-05-2013, 07:43 PM
  2. Any CAB options for R4041 ?
    Last Post: 03-01-2013, 02:08 PM
  3. LS Tractor R4041
    By heitjer in forum Owning/Operating
    Last Post: 06-16-2012, 12:21 AM
  4. Considering an R4041
    By mlucius in forum LS Tractor Owning/Operating
    Last Post: 09-21-2011, 11:27 AM
  5. R4041 Pics
    By boomer632 in forum LS Tractor Owning/Operating
    Last Post: 03-26-2011, 07:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
