Page 3 of 7 FirstFirst 123456 ... LastLast
Results 21 to 30 of 68
  1. #21
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    Default Re: My biggest stump
    Quote Originally Posted by Guesseral View Post
    I was wondering how I would be able to use my rear hydraulics for a continuse flow application. Is that strap something you made or is it something from LS?
    I bought the tractor with the hoe so I'm not sure if the dealer or the factory did the strap
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  2. #22
    Silver Member Mike1369's Avatar
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Baddest LS P7010C south of Palm Beach County
    Default
    Well since everyone is posting their biggest stump... Here's mine... Almost took the whole day... That sucker was in good
    My biggest stump-image-2529263931-jpg
    Bahahaha... Just kidding... I'm not that much of a rookie.... :-)
  3. #23
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    Mike, be careful that may exceed your lift capacity.
  4. #24
    Gold Member rocknrod's Avatar
    Join Date
    Oct 2010
    Posts
    280
    Hico, TX
    LS Tractor, Model R4010
    My biggest Rock so far
    LS Tractor R4010, Loader, 6ft Shredder, Box blade, Sun Shade, Pat's Easy Hitch, PTO Wood Chipper
  5. #25
    Veteran Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    1,464
    Livingston County, Michigan
    Kubota M8540, ZD1211 60"
    I Keep a small bungee cord in my tool box that use to hold my self canceling valve in case it tries to cancel out on me, to run my log splitter no tools necessary and free since it was already in my inventory
    Dave
  6. #26
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,360
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    My biggest stump-10-22-10_0823-jpgMy biggest stump-img_1154-jpgNot my biggest rock but the biggest I have a picture of. The largest one I had wouldn't fit in the bucket so I just shoved it about 100 yards into a creek wash hole to get it out of the pasture. SO FAR, the largest one single rock that we could measure is still at the bottom of one of our ponds and is about Volkswagen beetle size. The last photo is by far the largest although I never found the beginning or end of it and after a couple hours of digging, I just covered it back up. A big pine was growing on top of it and I found it when digging up the stump. The more I dug the more solid rock I got along with a whole nest of babies gathered around this one of various sizes.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  7. #27
    Join Date
    Dec 2012
    Posts
    1,464
    Don't have many stumps but here is the biggest rock i dug out of my field. I got in the way of plowing looked about like a 10 - 12" bolder when i first started digging.
    My biggest stump-20120525_123005_405-vi-jpg
    My biggest stump-20120525_123033_646-vi-jpg
    My biggest stump-20120525_123929_601-vi-jpg
    This is quite possibly the dumbest Chevy silverado commercial i have seen Pulling out a monster stump, If you believe this then its obvious that the OP was using the wrong flavor truck when he tried to pull his stump out with his truck. If it had a bow tie on it he would have had no problems. I've seen guys trying to pull out 3 or 4" trees stumps with tires on pavement in a 1 ton dually and the trucks and couldn't budge them
    http://www.ispot.tv/share/7dgh
    Dave
  8. #28
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    You are right I have seen big trucks not able to pull out small trees or bushes.
  9. #29
    New Member
    Join Date
    Oct 2012
    Posts
    8
    Goldsboro, NC
    LS/R4047
    Is that B.H. very easy to hook up and take off the tractor?
  10. #30
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    Quote Originally Posted by hkjones3 View Post
    YEP , two pins and two hoses.it takes some practice at first lining up the front and rear mounts , but once aligned , it slips right in.
    I can put it on and take it off in 1-5 minutes. just depends on how well I line up the tractor with it .
Similar Threads
  1. Stump Removal vs Stump Grinding
    By BoneheadNW in forum Owning/Operating
    Last Post: 06-24-2014, 02:02 PM
  2. Biggest trailer I've ever seen!
    By Mace Canute in forum Trailers & Transportation
    Last Post: 02-10-2012, 07:45 PM
  3. Biggest one I'VE done
    By KPark in forum Projects
    Last Post: 08-02-2009, 09:56 PM
  4. Biggest forks ever
    By AKwelder in forum Build-It Yourself
    Last Post: 11-25-2008, 03:44 PM
  5. Taking out a stump, a BIG stump
    By karmakanic in forum Projects
    Last Post: 06-29-2003, 04:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
