Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 68
  1. #31
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,955
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: My biggest stump
    My biggest stump-img_1214-jpgMy biggest stump-img_1221-jpgMy biggest stump to date is still in the ground. I was able to cut all the big roots all the way around but it is too wet to do anything else with it. I am thinking I will drop a chain under the root ball and see if I can pull it thru and cut all the small roots as I cant dig any closer with my back hoe. I think the LS P7010 might have the power to pull it thru. If not my other idea is to use it like a saw blade with 2 tractors and pull each one back and forth with the dragged tractor holding tension on the chain so it kinda saws its way thru.
    It only took me an hour to dig around it but it is so large that even with all the big roots cut, it is still solid and immovable at this point. The soil around it is water logged and some standing water so it is going to set like it is for a while till we stop getting rains every 3 days. It is hard to tell from the photos but I dug about 3 feet deep or more in some spots all the way around. It was filling up with water in the deeper spots that I dug. I didn't find any more roots below about 3 feet.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  2. #32
    Gold Member deathtoblackberries's Avatar
    Join Date
    Mar 2013
    Posts
    410
    Battle Ground, WA
    Kubota BX2380
    My neighbor across the street won the biggest stump pile contest
    My biggest stump-stumps-jpg
  3. #33
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Quote Originally Posted by Bladehauler View Post
    YEP , two pins and two hoses.it takes some practice at first lining up the front and rear mounts , but once aligned , it slips right in.
    I can put it on and take it off in 1-5 minutes. just depends on how well I line up the tractor with it .
    That's not bad at all. I'm seriously considering adding the BH to mine. Any idea what it weighs? I'm siding trailers now, and that could factor in....website doesn't list a weight.
  4. #34
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    Quote Originally Posted by GManBart View Post
    Im not sure what it weighs, I would guess 1000-1200 lbs. just by the way the tractor feels
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  5. #35
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Yeah, I figured it has to weigh about as much as the loader.
  6. #36
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,985
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    My biggest stump was still growing.
    About 18' tall.
    My biggest stump-p7260001-jpg My biggest stump-p7260006-jpg
  7. #37
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,196
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Quote Originally Posted by Xfaxman View Post
    About 18' tall.
    I've ripped up to 12 footers out of the ground during mud season in Northern new England. Was pretty easy and I actually transplated them and every one lived. Used a 3/8" or 1/2" chain that kinked and did not damage the bark very much. Damage the bark and it won't work.
    May I be the kind of person my dogs think I am,
  8. #38
    Platinum Member cartod's Avatar
    Join Date
    Aug 2008
    Posts
    872
    Northern, West Virginia
    JD 3320,255
  9. #39
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,253
    SouthEast Michigan
    Massey 1652 HST Cab
    This is the first stump I've dug with this tractor... Only a 12" Maple, but it was loaded full of wet clay which made it a real "you know what" to get out and move. But the good news is I'm getting a stump-bucket on Saturday
    Just finished digging it out, really rutted up my yard trying to get traction in the clay
    My biggest stump-4-23-13-048-jpg
    Trying to lift it with the forks to shake off the clay
    My biggest stump-4-23-13-050-jpg
    Flipping it a few times to move it - will have to wait for the clay to dry so I can shake some more out
    My biggest stump-4-23-13-052-jpg
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  10. #40
    Silver Member Mike1369's Avatar
    Join Date
    Dec 2012
    Posts
    222
    Miami, Fl
    Baddest LS P7010C south of Palm Beach County
    Default
    Reverse wheelie... Lol
Similar Threads
  1. Stump Removal vs Stump Grinding
    By BoneheadNW in forum Owning/Operating
    Last Post: 06-24-2014, 02:02 PM
  2. Biggest trailer I've ever seen!
    By Mace Canute in forum Trailers & Transportation
    Last Post: 02-10-2012, 07:45 PM
  3. Biggest one I'VE done
    By KPark in forum Projects
    Last Post: 08-02-2009, 09:56 PM
  4. Biggest forks ever
    By AKwelder in forum Build-It Yourself
    Last Post: 11-25-2008, 03:44 PM
  5. Taking out a stump, a BIG stump
    By karmakanic in forum Projects
    Last Post: 06-29-2003, 04:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
