Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Silver Member fredflintstone's Avatar
    Join Date
    Mar 2013
    Posts
    103
    michigan
    cub cadet LS4140
    Default Re: LS R4041
    the 4041 with a 6 foot tiller
  2. #12
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,179
    SouthEast Michigan
    Massey 1652 HST Cab
    Default
    U go hydro or shuttle?
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  3. #13
    Join Date
    Mar 2013
    Posts
    103
    michigan
    cub cadet LS4140
    he only had the shuttel in 4041 probly wont sleep for the next few lol, first
    thing remove the seat stops, thanks for that 1
  4. #14
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    Quote Originally Posted by boomer632 View Post
    Its actually the same motor bolt for bolt. 47 comes from factory with injectors turned up a bit to get the extra 6hp out of the 41 motor.
    Check the specs for bore and stroke. In 2010, the R4020 (47 HP) had a longer stroke than the R4010 (41 HP). These two became the 4041 and 4047 the next year. My manual is for 2010. So, you might be correct, and they got the horsepower a different way the next year.
    The Corporate Empire is NOT a Constitutional Republic...
    ...but it plays one on TV.
  5. #15
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    Congrats Fred!
  6. #16
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    I am wondering if Fred Flintstone got the two feet drive option????
    Yabba dabba doo!
  7. #17
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Quote Originally Posted by Short Game View Post
    The way I look at it, when they are getting more horsepower from the same basic engine, the cost will be in wear. That's why I preferred to go with the lower HP. In the case of the 4010/4020 or 4041/4047, it is a longer stroke.
    It can actually work the opposite way in some situations. To do the same job (load, speed, etc) the engine with more power won't have to turn as fast, or will be turning the same speed, at a lower manifold pressure, so the wear will actually be less. RPM and MP are directly related to wear rates when the conditions are the same.
    If the engines have different bore and stroke specs, all that goes out the window.
  8. #18
    Join Date
    Mar 2013
    Posts
    103
    michigan
    cub cadet LS4140
    delevery between 330/4 tomorrow
  9. #19
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Quote Originally Posted by fredflintstone View Post
    I only hope you're as happy with yours as I am with mine!
  10. #20
    Join Date
    Mar 2013
    Posts
    103
    michigan
    cub cadet LS4140
    whare would i get the hooks to weld onto the bucket? im really hoping the ls works out. im on the taller
    side and my complaint has been lack of room in the seat, have to pull the stops and see how that works out.
    But looking forward to putting the 4041 to work
Similar Threads
  1. NH Boomer 40 accessories for LS R4041?
    By boomer632 in forum LS Tractor Owning/Operating
    Last Post: 07-05-2015, 02:05 AM
  2. New R4041 !!
    By TSO in forum LS Tractor Owning/Operating
    Last Post: 03-05-2013, 08:43 PM
  3. LS Tractor R4041
    By heitjer in forum Owning/Operating
    Last Post: 06-16-2012, 01:21 AM
  4. Considering an R4041
    By mlucius in forum LS Tractor Owning/Operating
    Last Post: 09-21-2011, 12:27 PM
  5. R4041 Pics
    Last Post: 03-26-2011, 08:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
