Results 1 to 6 of 6
  1. #1
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,133
    SouthEast Michigan
    Massey 1652 HST Cab
    Default Broke something today
    ... Using my box blade tines to scarify an area that will become a garden. Apparently I snagged a root, pulling the front of the blade down as I crept forward. It actually bent the top link causing the BB to roll up even further in the back. Apparently the stress was too much and it sheared the metal on the BB near the passenger side 3pt pin.
    Broke something today-forumrunner_20130331_204935-png
    Broke something today-forumrunner_20130331_204943-png
    Broke something today-forumrunner_20130331_205004-png
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  2. #2
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Default Re: Broke something today
    Ouch!
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  3. #3
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,711
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Man your scarifiers must be tougher than mine, when ever I hang one it either bends sideways or breaks the tine. I have never bent a top link in my live so you have encountered a hopefully once in a lifetime experience. Looks like it is time to break out the welder for the box blade. I doubt that you can do much with the top link other than replace it. In the future, try not to operate it with it screwed out quite that far if possible. Luckily they are not that expensive to replace.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  4. #4
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,715
    Waynesboro Va
    John Deere X310, JD LA 145
    Looks like an easy fix on the BB, Glad it wasn't worse.
  5. #5
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    LS R4010 & Cub Cadet 7300
    I got what looks like that exact same box blade with my CubCadet. It came to me, beefed up with some structure to mount a Warn 12,000 pound winch, a receiver hitch put all the way through it, and also had the end plates doubled with a layer of 3/16 diamond plate. I don't know how much use it had had, but I broke it in the same place. It was not from ripping, but from grading an old drive with lots of nasty big rocks that stuck up and would sometimes snag very hard.
    To repair it, I ground V grooves and made repeated welds to reattach the broken off end. I then doubled both of the inner sides where the break had been with 2 1/2" X 1/4" angle irons, welded anywhere I could weld them, and drilled those through for the pins.
    No time for a picture now, but I will get some later if you want.
    The Corporate Empire is NOT a Constitutional Republic...
    ...but it plays one on TV.
  6. #6
    Elite Member
    Join Date
    Jun 2011
    Posts
    3,007
    Sunny SW Washington
    Here's pics of the repair. When the one side broke, the other side cracked. So I ground grooves into the crack and welded it too. I know my vertical welds are nothing pretty.
    Also, here is the modification it came with to mount the winch and the receiver hitch. I added pegs to store chains and the shelf for the chainsaw gas and bar oil. I figured out a way to store my homemade bucket forks on it too. I also have a place to mount and pin in my homemade wood splitter that runs off the remotes. All that and good ballast too.
    Broke something today-cub-air-filters-012-jpgBroke something today-cub-air-filters-015-jpgBroke something today-cub-air-filters-014-jpgBroke something today-cub-air-filters-013-jpgBroke something today-cub-air-filters-016-jpg
    Broke something today-cub-air-filters-021-jpgBroke something today-cub-air-filters-020-jpgBroke something today-cub-air-filters-019-jpgBroke something today-cub-air-filters-018-jpgBroke something today-cub-air-filters-017-jpg
Similar Threads
  1. Broke down and did it today
    By kootch88 in forum Mahindra Buying/Pricing
    Last Post: 05-24-2013, 12:56 PM
  2. b7100 broke today need help
    By badbowtie in forum Parts/Repairs
    Last Post: 05-23-2012, 04:24 PM
  3. My 2520 broke today...
    By Gobblin Tom in forum John Deere Owning/Operating
    Last Post: 06-20-2011, 01:09 PM
  4. Broke my tractoe today.
    By Sulla in forum Kioti Owning/Operating
    Last Post: 05-31-2011, 09:12 PM
  5. I broke it today!
    By skipro3 in forum Montana
    Last Post: 04-09-2009, 03:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
