Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
  1. #11
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Default Re: Question about trailering a LS R4041
    I haul my tractor on a 12K trailer and pull it with an 05 Dodge 2500 Hemi, my towing capasity is only 8500lbs and the newer 1/2 ton trucks have larger towing capasity than my older 3/4 ton. The real problem is with breaking on the truck even with trailer breaks. I know the Dodge trucks with a Hemi 1/2 or 3/4 ton and the Diesel 3/4 all have front and rear (really large) disk breaks, not sure about the other manufactures I really don't look. I think you have enough truck but I don't know what your truck is rated to tow or what size breakes you have.
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  2. #12
    New Member
    Join Date
    Mar 2013
    Posts
    19
    Vicksburg, MS
    2012 LS R4041
    Thanks guys. Y'all have been very helpful. I'm picking up my R4041 Friday. One thing I know for sure, I'm adding brakes to the trailer.
  3. #13
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,027
    SouthEast Michigan
    Massey 1652 HST Cab
    Default
    Quote Originally Posted by Guesseral View Post
    Agreed. My 2010 Tundra (5.7L 381hp/401ya) had the best drivetrain I've ever had in a gas truck, and was rated to pull almost 11000lbs. It had the "largest brakes in the class" according to the marketing, but I don't know if that was true.
    However, I don't think and half ton has any business moving that much weight, especially at highway speeds . You might be able to pull it, but handling & stopping is more of a concern.
    But again, your truck should handle it fine, just drive cautiously. If you don't already have one, trail()888er brake controllers can be purchased for less than $100, and usually have an available plug & play harness that won't require splicing if your truck is pre-wired with the harness.
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  4. #14
    Join Date
    Nov 2012
    Posts
    1,485
    mansfield,Il
    john deere
    Fowler you are the best .
  5. #15
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,298
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    When I am trailering my tractor, I set the electric brake controller to apply the trailer brakes fairly strong but not enough to lock up the tires. I can stop tractor/trailer/truck just about as fast as I can stop the truck/trailer when empty. Those dual axle brakes are great and I don't need to use the truck brakes heavily to stop.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  6. #16
    New Member
    Join Date
    Aug 2009
    Posts
    20
    Central Texas - Coryell County
    2013 LS R4041H, 1948 Ford 8N
    I towed my new R4041H home today on a 16ft dual axle trailer with electric brakes using my Honda Ridgeline pickup (v6 - 255 hp). I limited my speed to no more than 60 MPH for safety reasons, but it had no trouble pulling the trailer for over 100 miles through the central Texas hill country from Austin to Gatesville.
  7. #17
    Join Date
    Apr 2012
    Posts
    4,027
    SouthEast Michigan
    Massey 1652 HST Cab
    Default
    Quote Originally Posted by BigMoB View Post
    Nice. Isn't the tow Max on that around 5000lbs?
  8. #18
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    Quote Originally Posted by TSO View Post
    It is...and a 4041 with loader, and bucket is over 5k without the trailer
  9. #19
    New Member
    Join Date
    Aug 2009
    Posts
    20
    The maximum towing limit for the Ridgeline is 5000 lbs, but since I had brakes on the trailer it had no trouble stopping the load. I figured that I was prettly close to 5000 lbs with the loader and tractor combined. It would have been easier with a 3/4 ton pickup, but I got the job done anyway.
    Question about trailering a LS R4041-towing-home-ls-tractor-jpg
  10. #20
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    A 4041 with loader, and bucket is over 5,000, plus you have a canopy....probably 5,300 minimum, then another 1,500+ for the trailer. So, you were only about a ton over the listed max....brakes, or not.
    You did it, but that doesn't really make it safe. Judging from the squat on the rear of the Ridgeline, it's pretty obviously overloaded.
Similar Threads
  1. Trailering question
    By vicar in forum Kubota Owning/Operating
    Last Post: 05-17-2008, 07:27 AM
  2. Question on trailering an L3400
    By Rotty in forum Kubota Buying/Pricing
    Last Post: 03-04-2008, 10:20 AM
  3. Trailering question
    By adegiulio in forum Owning/Operating
    Last Post: 10-14-2007, 10:26 PM
  4. Trailering Question?
    By MidMichigan in forum Kubota Owning/Operating
    Last Post: 02-29-2004, 10:53 PM
  5. Trailering question
    By Anonymous Poster in forum Owning/Operating
    Last Post: 10-31-2002, 11:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
