Results 1 to 8 of 8
  1. #1
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,179
    SouthEast Michigan
    Massey 1652 HST Cab
    Default Identify this wiring harness:
    It's on the left side between the seat & fender... I'm looking for a spot to mount a 12v outlet, was going to run a wire, but figured I'd use this if was a power lead.
    Thoughts?
    Identify this wiring harness:-forumrunner_20130528_194739-png
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  2. #2
    Platinum Member rwork's Avatar
    Join Date
    Apr 2012
    Posts
    605
    Mississippi Gulf Coast
    Kubota B6100 LS R3039H
    Default
    Not sure, but that could well be the seat safety switch. If so, I'd pass on that one. Might affect ability to complete ignition circuit.
    I'd look for the wires going to the rear light or rear receptacle.
    2012 LS R3039H, 6' Howse HD Box Blade, 4' Root Grapple, CID Stump Bucket
    1975 Kubota B6100, Craftsman Garden Tractor, eXMark Lazer Z mower.
  3. #3
    Platinum Member joemd11's Avatar
    Join Date
    Jan 2010
    Posts
    990
    Western Pa
    LS R3039, Power King 1614, Simplicity Soveriegn 75th Aniv model.
    Default Re: Identify this wiring harness:
    My R3039 has a wire harness on the right side of the seat that is unused. Don't know what it is for. I think if I ever add some lights that I'll just use the 7-pin connector for the trailer plug. That way I won't have to splice into any factory wiring.
  4. #4
    Gold Member mangus580's Avatar
    Join Date
    Sep 2010
    Posts
    490
    Western, NY
    Bolens (Iseki) H1502; LS R3039
    I have a wiring diagram I could scan in - not sure it will help. What color are the wires?
  5. #5
    Veteran Member the old grind's Avatar
    Join Date
    Jul 2012
    Posts
    1,324
    Mid-Michigan
    NH T-1520 HST, JD 5210 2WD, Case DX26 HST, Terramite T5C
    If you're in doubt, running a wire isn't so tough. A diagram should show the best place to tap (electrically), other than location alone. Match the fuse to the wire gauge, .. both to the load. If you use a std auto-cig lighter 'outlet' put it in-line or where replacement will be easy, they can be fragile. Be sure the lead to your accessory won't be a trip point if you hop on & off a lot. (Put the socket near the accy's mount.)
    A lot depends on o'all use, too. If this is for a winch and not just a radio, using a particular plug/socket might be wise to handle high current, last the longest, and IMO too, a 7-wire trailer plug/socket wouldn't be over-kill. You can buy or make up adapters for other plug types.
  6. #6
    Join Date
    Apr 2012
    Posts
    4,179
    SouthEast Michigan
    Massey 1652 HST Cab
    Default
    Quote Originally Posted by mangus580 View Post
    I'd love to see the diagram if/when you get a chance.
    Good point T.O.G.
  7. #7
    Silver Member boomer632's Avatar
    Join Date
    Jan 2011
    Posts
    205
    Steeler Country
    2011 LS R4041EZ - 2014 Bad Boy CZT Elite - 1948 Ford 8N
    Default
    Here is where I put mine.. mostly used as phone charger. Has blue LED inside socket.. matches tractor nicely.
    Identify this wiring harness:-forumrunner_20130529_162317-png
    2011 LS R4041EZ - 1948 Ford 8N - 2014 Bad Boy CZT Elite
  8. #8
    Join Date
    Sep 2010
    Posts
    490
    Western, NY
    If you look in my R3039 Mods thread, you will see how I am powering aux wiring. Basically I have a snowplow type solenoid under the hood by the battery. That is controlled via a wire from the key. I have a 30 amp fuse between the battery and solenoid. I then have a 6 outlet fusebox under the dash that has power coming from the solenoid. This gives me 6 key controlled circuits to work with, using the same fuses as the tractor. (guess I only have one pic from the project...)
    Identify this wiring harness:-2013-02-13-12-52-a
Similar Threads
  1. WIRING HARNESS FOR 66 MF 135
    By William Cable in forum Parts/Repairs
    Last Post: 05-11-2012, 01:27 PM
  2. Wiring Harness
    By Carl Dressel in forum Parts/Repairs
    Last Post: 12-12-2011, 07:07 PM
  3. Need wiring harness
    By advision in forum New Holland Owning/Operating
    Last Post: 10-07-2010, 01:29 PM
  4. wiring harness
    By kubotam8540 in forum Kubota Owning/Operating
    Last Post: 02-25-2009, 09:50 PM
  5. Wiring Harness
    By Anonymous Poster in forum Iseki
    Last Post: 02-08-2003, 02:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
