Underdog57
I have a 2013 R4041 H. The bolt with 2 nuts broke on my top link bracket, it appears it is welded on the back side only. I was carrying my 1800# ballast box (my 3-point is rated for about 2700#). I just hit a bump and it broke.
Question 1: the tractor is 22 months old and has 216 hrs on it, do you think it is a warranty issue? I have had only 1 minor issue with the tractor since it was new.
#2: Should I just weld the same bolt back in from both sides and grind down the inside so that little "flapper" can fit properly, or just weld it good and leave the flapper down?
#3: Anybody else have this problem?
Let me know what you think,
Thanks
Thanks
