I broke the key on my new tractor and what I did to fix it.
   / I broke the key on my new tractor and what I did to fix it. #1
Plas62
Hogansville, GA
LS XJ2025H
I was getting off my tractor (xj2025h) Saturday and hit the ignition key with my knee and bent it over pretty badly. I had hit the key before with my knee and bent it slightly and was able to straighten it out. When I tried to bend it back it Saturday it snapped off.
LS just put the key in a bad location and the key sticks to far out of the ignition. I suspect I'm not the first person this has happened to. Below is what I did to my spare key to try to modify it so this would not happen again.
I had a knob from an obsolete piece of automation that we scrapped out at work. The knob had a 10x 1.5 mm steel threaded insert in it which just happened to be slightly smaller than the width of the key.
I put my spare key in the ignition and marked it with a magic marker, so I would know how much of the key I would need to leave sticking out. I then cut my spare key off just under the plastic head of the key and slightly tapered the end I had cut off on my disc sander, so I would have a lead in when screwing the knob onto the end of the key. (I had tested this on the broken end of the old key before cutting up my spare key). I then chucked up the cutoff spare key in the vise on my mill and then screwed the knb onto the shank of the key. I then mixed up some JB Weld and filled in the area between the shank of the key and the threads of the insert. I even drilled a hole in it for my key chain. Below are pic's of the finished product. I'm happy with how it turned out.
   / I broke the key on my new tractor and what I did to fix it. #2
Well done Mate! :thumbsup:
Strange that LS would design their key(s) to originally fit like that... an accident waiting to happen. My JD keys are short & squat = no danger of whacking them.
Mind you, I'm a short arse. :)
   / I broke the key on my new tractor and what I did to fix it. #3
I like that!
   / I broke the key on my new tractor and what I did to fix it. #4
Do you wear knee pads now? :)
Nope, the key's short enough now my knees miss it.
   / I broke the key on my new tractor and what I did to fix it. #6
That is a very crafty solution. Closer to the dash and much easier to turn.
   / I broke the key on my new tractor and what I did to fix it. #7
Broke mine off within a week of owning it. Took the stub and soldered it to two brass flat washers. It is completely flush with the dash now.
   / I broke the key on my new tractor and what I did to fix it. #8
I've now bent and bent back my key 4 times by hitting it with my leg on accident when jumping off. Anyone consider remounting the ignition lock somewhere else in the plastic dash?
   / I broke the key on my new tractor and what I did to fix it. #9
Broke my key off leaving about an eighth of an inch in the plastic fob; soldered the two together with the fob at 90* to the toothed section. It sits flush with the face of the switch, causing no more trouble
   / I broke the key on my new tractor and what I did to fix it. #10
I was hitting my key with my knee and bending it when getting off the tractor. I had a new one made at the local Farmer's Co-op, and it has a much shorter bow (head), so I don't hit it.
2012 Volkswagen Tiguan AWD SUV (A55853)
2012 Volkswagen...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
2012 Ford F-250 Pickup Truck (A55852)
2012 Ford F-250...
(2) 5' TRAILER RAMPS (A57192)
(2) 5' TRAILER...
PT Cattle Feeder (A56469)
PT Cattle Feeder...
2007 Hyundai Sonata GLS Sedan (A55853)
2007 Hyundai...
