Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    New Member
    Join Date
    May 2015
    Posts
    7
    Georgia
    N/a
    Default 3039R....engine frame broke!,,,
    I was brush hogging an old field...pop and bad noise...quickly shut off the engine. Investigated...busted frame next to where the loader bolts on. 3039R....engine frame broke!,,,-img_2088-jpg3039R....engine frame broke!,,,-img_2092-jpg3039R....engine frame broke!,,,-img_0368-png
    Any suggestions?
  2. #2
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    5,851
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    Default Re: 3039R....engine frame broke!,,,
    WOW! Still under warranty I hope??
  3. #3
    New Member
    Join Date
    May 2015
    Posts
    7
    Georgia
    N/a
    No, it is a 2012....feels like my pocket change is going to find a new home. This is going to be expensive.
  4. #4
    Join Date
    Dec 2013
    Posts
    1,575
    Southern Alberta, Canada
    4410 and F-935 John Deere, MF 245
    I would just have it welded. A good welder should be able to do it without removing the frame from the tractor though it would be a lot easier removed. What would bother me more is the question as to why it broke.
  5. #5
    Gold Member airbiscuit's Avatar
    Join Date
    Aug 2004
    Posts
    455
    Wisconsin
    New Holland T2310, New Holland TC21DA, Farmall H *** Previously - 1941 John Deere B, Shibaura 1500, John Deere 850, Bobcat 642, New Holland 1925
    Quote Originally Posted by pmsmechanic View Post
    Times 2 on why it broke? You might talk with some truckers and see if they know of anyone who repairs frames on semi tractor trailers.
  6. #6
    Veteran Member Sysop's Avatar
    Join Date
    Jun 2013
    Posts
    2,347
    Fairmont, WV
    Mahindra 4035HST purchased 2013 - John Deere 42" Geardrive w/bagger purchased 2012 - Craftsman 42" HST purchased 2006
    A good welder wouldn't try to weld that on the tractor. To do a good weld on a chunk like that, it needs to be removed so the break can be properly ground out and filled with weld. Without grinding it out, all anyone will ever do is put a patch of weld over the crack and it will happen again...
    *edit* Upon looking at the pics a bit more, I don't think a good welder would even try to weld that at that hole. Removing the entire piece of subframe, cutting a "stepped notch" in the frame to weld in new material, and redrilling the hole would be a "good" welder's fix...
    **edit** The stepped notch referred to above is to prevent the weld from being along a shearing path. Here is an example of the process done on a truck frame.
  7. #7
    Join Date
    Dec 2011
    Posts
    5,851
    Virginia USA
    Agree that it would be good to determine why it cracked -- was there any misuse/abuse of the loader?
    I sure wouldn't do a weld repair without patching over that crack with some extra plating that is welded at least a few inches away from the crack. Really need to do something to spread out the repair. A diamond patch would probably be best.
  8. #8
    Join Date
    Aug 2004
    Posts
    455
    Wisconsin
    Anyone who repairs frames on 80,000 lb trucks will know what to do.
  9. #9
    New Member
    Join Date
    Jan 2017
    Posts
    21
    Sykesville, MD
    Bobcat Toolcat 5600
    It is a weld job with straps above and below the bolt. I do not agree you have to remove the sub frame - if there even is one (can't enlarge the frame pic$.
  10. #10
    Gold Member Snobdds's Avatar
    Join Date
    Feb 2016
    Posts
    494
    Wyoming
    MF gc1710, Cat 305C
    A good welder would have a process to repair that. However, I would be knocking at JD to let them know a frame that should not break for 25 years, broke. They might help with the fix, because this is a super bad PR for them. One youtube video of this is a crushing blow for any manufacturer.
Similar Threads
  1. Ford 4400 in frame engine rebuild
    By richwilshaw in forum Parts/Repairs
    Last Post: 10-16-2015, 08:01 PM
  2. Backhoe L48 sub frame broke
    By messtrap in forum Kubota Owning/Operating
    Last Post: 10-02-2014, 11:07 PM
  3. Pro200 frame failure-broke in half frame
    By inthechateau in forum Gravely & Ariens
    Last Post: 06-16-2014, 04:30 PM
  4. broke frame
    By trctrguy in forum Mahindra Owning/Operating
    Last Post: 04-13-2010, 09:09 PM
  5. 2004 NH TZ24DA frame broke!!!!!!
    By mrford49 in forum New Holland Owning/Operating
    Last Post: 08-28-2008, 06:51 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
