Had my first issue with the the tractor. Has 133 hours on it and was backfilling a 400’ irrigation trench. The red exclamation point light and the light that looks like a gas pump illuminated, would not rev past 1400 RPM, and gave an error code of F02 and 97.
Quick search in the owners manual showed that the gas pump light means the fuel filter needs service. The 97 code means water in fuel sensor.
I drained the filter and water separator then pressed the primer button a dozen times and went back to work with no problems.
I fuel the tractor from a transfer tank in my pickup with a goldenrod filter/water separator. I know I had to drain a little water out of the goldenrod last time I filled the tractor, but I guess it doesn’t remove all of the water.
So just a self inflicted wound. The tractor never faltered so I think the tractor water separators did their job.
