jdom84
Gold Member
I built these pallet forks from a pile of (s)crap steel I have in my back yard and today Ive been moving things around in my yard with them, now that it stopped raining for a bit. I have some videos ill put on youtube later.
I built it out of .25 thick steel 2x2 square tube and 2 chunks of 6 inch channel and some 2x3/16th channel on the sides and the center.
Added this hitch receiver today
SSQA attach points
I built the forks from 2.5 inch wide (I think) 5160 steel and backed them with 2" channel with a complete weld all the way around. There is a high chance that the weld will fail because I did no special preheat/post heat... before using them I measured from top to tip and it was 46 3/8"
the top of the forks hang on the 2x2 tube
this is how I kept the forks from bouncing up and down, but turned out to be a nightmare so I'm going to cut it off and redesign it with spring loaded mech.
I recently did (still doing) a major remodel on the entire first floor of my house so there was a stove I pulled out of the house I need to put in the garage. The stove in the garage I already moved out with the bucket.
I also picked up my 5 foot box blade with no issues. No pictures, only crappy video
After I was done moving things I remeasured and it was exactly the same as when I started
SSQA attach points
